SSL HTTPS connection from "outside" interface
robbo79871
Level 3
Level 3
Hi, i'm trying to establish a HTTPS connection to my ASA from another "site" in packet tracer. I can ping across the sites and into the "inside" network of the other site but cannot HTTPS into the ASA or the web server itself also. Here is the config for the ASA that i want to HTTPS into:
hostname ASA2
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
switchport access vlan 30
interface Ethernet0/2
interface Ethernet0/3
interface Vlan2
nameif outside
security-level 0
ip address 172.16.30.2 255.255.255.0
interface Vlan30
nameif inside
security-level 100
ip address 10.30.0.1 255.255.255.0
webvpn
enable outside
enable inside
object network asa_inside_address
subnet 10.30.0.1 255.255.255.255
object network inside_network
subnet 10.30.0.0 255.255.255.0
route outside 0.0.0.0 0.0.0.0 172.16.30.1 1 <<<<<This is just to the router on the edge for the frame relay, everything works as far as connectivity goes anyway
access-list website_outside extended permit tcp any object asa_inside_address eq 443
access-list website_outside extended permit icmp any object asa_inside_address
access-list website_outside extended permit icmp any object inside_network
access-list website_outside extended permit udp any 10.30.0.0 255.255.255.0
access-group website_outside in interface outside
group-policy webvpn internal
group-policy webvpn attributes
vpn-tunnel-protocol ssl-clientless
webvpn
url-list value test1
username bob password 4IncP7vTjpaba2aF encrypted
username bob attributes
vpn-group-policy webvpn
class-map inspect
match default-inspection-traffic
class-map test
class-map ssh
policy-map global
class inspect
inspect icmp
class test
service-policy global global
tunnel-group webvpn type remote-access
tunnel-group webvpn general-attributes
default-group-policy webvpn
And here is the config for the ASA on the other "site" with the PC behind it  that i'm using HTTPS on:
hostname ASA1
names
switchport access vlan 20
interface Vlan2
nameif outside
security-level 0
ip address 172.16.20.2 255.255.255.0
interface Vlan20
nameif inside
security-level 100
ip address 10.20.0.1 255.255.255.0
webvpn
enable
route outside 0.0.0.0 0.0.0.0 172.16.20.1 1
access-list test extended permit icmp 10.30.0.0 255.255.255.0 10.20.0.0 255.255.255.0
access-group test in interface outside
class-map inspect
policy-map global
class inspect
inspect icmp
I would just like to point out that the HTTPS works on "ASA2" because I've tested it on the inside interface from a PC there and it all works. Its just connections from the "outside" that do not work
gaowen
Level 3
Level 3
Hi Rob,
your ACL on the first box will need:
access-list website_outside line 1 extended permit tcp any object inside_network eq 443
access-list website_outside line 1 extended permit tcp any host 172.16.30.2 eq 443
I think I'm right in saying you are tring to HTTPS to that outside interface address 172.16.30.2 and also through the box to the internal network object inside_network
Gareth
11 Replies 11
gaowen
Level 3
Level 3
Hi Rob,
Gareth
Thank you very much that worked perfectly.
Would the same kind of concept be applied to other examples such trying to SSH to the edge router and the edge router connecting to a radius server on the inside network? Would the ports or ACL need to enable a UDP connection on the OUTSIDE interface to and not just the inside one?
Many thanks
Hi Rob,
yes for the SSH but no for the RADIUS, as RADIUS is initiated by the firewall itself (using relevant interface IP address).
If you had an outbound ACL on the inside interface then you'd need to let it through that. But you don't have one and it's best to keep it that way 😛
Gareth
Yeah i didnt see the point in an ACL for outbound traffic on the inside. I did have this ACL though:
I thought that would enable the router to send the UDP radius traffic through the ASA to the appropriate address on the INSIDE interface.
It doesn't work though, it just comes up Login Invalid from PC's on the INSIDE as well, I'm not even talking about the OUTSIDE yet.
Would you have any suggestions on that?
Thanks again
Tried these 2 then and no luck
ASA2(config)#access-list website_outside extended permit udp any host 172.16.30.2 eq 1645
do you mean firewall?
where is the RADIUS client and where is the server and what's their IP addresses?
The client PC is on the INSIDE network and so is the AAA Radius server. The router that i want to SSH to is on the OUTSIDE interface.
Here is the router config for the radius server
radius-server host 10.30.0.11 auth-port 1645
radius-server key key
The AAA details are:
Client Name R1
Client IP 172.16.30.1
Key key
The client machine would be a 10.30.0.0/24 address.
I can ping the AAA server from the OUTSIDE interface also through part of the ACL's i have set up.
are you doing dot1x? so your supplicant, authenticator and authentication server are all on the same LAN? It sounds like you need to figure out what your traffic flows are going to be, it's not an ACL issue
As far as i'm aware, no. Sorry i'm not as experinced with configuring Radius servers.
So the ACL i have configured "access-list website_outside extended permit udp any 10.30.0.0 255.255.255.0" would be enough for it to work?
The traffic flow would go like this:
Internal PC on the inside interface makes SSH connection
Past the OUTSIDE interface to the Router on the edge
The Router then tries to contact the AAA server on the INSIDE
The AAA server then sends the authentication response back to it
Then the router should send the response back to the INSIDE internal client.
I think I'm right in saying that but I'm not 100% because i haven't done AAA as much.
okay well i'd set up a packet capture on the outside interface to check you're getting hits:
cap cap1 circular-buffer interface outside match ip any any
then do your thing with SSH
then
show cap cap1
look for your ssh packets leaving the interface and then your RADIUS packets coming in the other direction slightly after. Based on output from that I'd enable debugging on the router and/or the ACS.
Gareth
Unfortunately packet tracer doesn't support those types of commands, i would have to move GNS3 to do that.
Any other way or is that really the only main step forward?
not sure, not familiar with the product. I'd move to GNS3 anyway it's worth the investment in time.
