static PAT problem on ASA 7.2
jasonww04
Here are the relevant parts of my config:
interface Vlan1
nameif inside
security-level 100
ip address 172.18.67.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 71.x.x.x 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list NAT extended permit ip 172.18.67.0 255.255.255.0 10.11.0.0 255.255.0.0
access-list NAT extended permit ip 172.18.67.0 255.255.255.0 10.41.0.0 255.255.0.0
access-list Port_Forwarding-ACL extended permit tcp any host 172.18.67.2 eq 3389
global (outside) 1 interface
nat (inside) 0 access-list NAT
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp interface 3389 172.18.67.2 3389 netmask 255.255.255.255
access-group Port_Forwarding-ACL in interface outside
route outside 0.0.0.0 0.0.0.0 71.169.11.1 1
Here is a packet tracer output:
eas-ny-pinn# packet-tracer input outside tcp 1.1.1.1 3389 172.18.67.2 3389
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Additional Information:
Found no matching flow, creating a new flow
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   172.18.67.0     255.255.255.0   inside
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: HOST-LIMIT
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: NAT
Subtype: rpf-check
Result: DROP
Config:
  match tcp inside host 172.18.67.2 eq 3389 outside any
    static translation to 71.169.11.10/3389
    translate_hits = 0, untranslate_hits = 6
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Why is this failing?
Try adding
access-list Port_Forwarding-ACL extended permit tcp any interface outside eq 3389
Then test the actual connection again and "packet-tracer" if you want.
- Jouni
Jouni Forss
Its failing because you are targetting the local IP address of the destination host in the "packet-tracer" command.
If someone on the external network were to connect to this host then the destination IP address would be that of your "outside" interface.
Use the "outside" interface IP address as the destination IP in the "packet-tracer" command and post that output if there is still a problem with it
- Jouni
This is what I get now.
eas-ny-pinn# packet-tracer input outside tcp 1.1.1.1 3389 71.169.11.10 3389
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Phase: 2
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
    translate_hits = 0, untranslate_hits = 18
NAT divert to egress interface inside
Untranslate 71.169.11.10/3389 to 172.18.67.2/3389 using netmask 255.255.255.255
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-status: up
output-status: up
Action: drop
Try adding
- Jouni
That fixed it. I'm always screwing up ACLs on interfaces when it comes to NAT. No one outside the network is trying to reach the private IP, that's what the NAT does.
