Strange Problem accessing Webserver through Site 2 Site VPN
stuffy001
i have a very interesting problem ;-)
I have a Site-2-Site VPN. On Location A i have a Webserver (Apach / Ubuntu 14.04 LTS). The Apache has no restirctions from where to access.
On Location A, i can access the Webserver. When i manually connect via Cisco Client to Location A from somewhere, i can access the Webserver, too.
When i try to access the Webserver from Location A via Site 2 Site VPN, i can not. I always get a time-out. I have tried from different PCs by using different browsers (Chrome, IE).
What is absolutely strange: i can ping the webserver from the client (in Location B) and i get an answer by using telnet to port 80 and no timeout!
I have no problem to access another Webserver via https.
When i try to access the webserver in Location A from another Location C via Site-2-Site , it works.
So.... now i am really at the end of my ideas.
Location A: ASA 5505, 9.24
Location B: ASA 5505, 9.24
There is no http filter active in the default inspections....
Micha
Maykol Rojas
Hello;
Good, this is a fun one. Can you do a NAT on site A for just one host and NAT it to the inside interface of the ASA to test?
Also, have you taken a capture? whats the reason for the Turning down the connection?
Let us know.
Mike.
Mike
