strange problem in Pix
MUHAMMAD SALEEM
I have strange problem, I don’t understand where the problem is?
I have one website on MS 2000 Advance server with IIS 5.0, one CA server built-in into MS 2000 Advance server on another computer, my website is secured certificate issued by this CA certificate 128 bits of encryption and I have one Mdeamon web based Email system with its own made SSL certificate,
Both servers are behind Cisco Pix Firewall 520 series with IOS 5.1(4), the configuration is ok, this scenario was working perfect with NO problem but since last two days all of the sudden my website is behaving abnormally on SSL web request, website works fine with some clients and NOT responding with some other clients, but the main thing is Mdeamon web based Email system with its own made SSL certificate is working fine with no problem, its responding for both SSL and Non SSL request BUT my website is NOT responding totally, I have reinstall IIS, reinstall windows 2000,reinstalled CA server but whenever I use new fresh IIS my website works for a while and again starting abnormally
I tried to bypass Pix firewall for the website and website responded but I am not sure, is it really Pix firewall problem or not?
I will appreciate the urgent response of this matter
Saleem
Networks Manager
KFUPM, KSA
Mobile: +966-508205722
nkhawaja
when the problem is happening, try bypassing the PIX. If it is working when you install IIS, then it stops working, it may not be a PIX issue. but in any case, get syslog messages from the PIX
Assalam-o-alikum, Nadeem,
I am sorry for this late reply, I have been trying to find syslog server PFSS software nut I could not find it, can u please give me the link so I would download it and give you syslog messages
Saleem
