Strange VPN Remote Issue
ciscosom
we have configured IPSEC Remote VPN on ASA 5510. Remote client is able to successfully authenticate and establish a tunnel , however user will not be able to ping any inside Hosts . As troubleshooting measure , i did enable ICMp trace 255 , i see the VPN Client ICMP request and a echo reply back from the Inside host hitting the Inside Interface of the Firewall . Can you please go through the configuration and let me know if anything needs to be changed .
Path the User will take is
VPn Usr-->Firewall ( inside ip 10.10.10.2)->L3switch (10.10.10.1)->Host (10.10.10.5)
16 Replies 16
Can u try specific networks rather then using "any" in your nat0 acl?
Thanks for taking time to go through my Issue nomair . I modified the ip's but that did not make any differance
