Stuck on a NAT problem
handsy
Level 5
Level 5
I'm stuck!
I need to get to an IP address on the other side of my Cisco ASA5555-X running 9.5.
Here's the important info (IPs obfuscated for obvious reasons):
  • Source IP can be anything
  • Destination IP for clients is 10.92.200.1 (int-map)
  • NAT'ed to 66.77.88.1 (ext-map)
  • Source must also be translated to use Interface IP of destination interface
I just cannot get my head round this one, basically I'm trying to get a basic NAT done, followed by a Source IP overwrite.
My initial attempt:
nat (inside,outside) source dynamic any interface destination static ext-map ext-map
...but that clearly misses the step where I translate int-map to ext-map. Can I even do this in 1 line of config??
Matias Ortiz
Level 2
Level 2
Hi handsy, you may try with:
object network OBJ-10.92.200.1
subnet 10.92.200.1 255.255.255.255
nat (inside,outside) source static any OBJ-66.77.88.1 destination static OBJ-10.92.200.1 OBJ-10.92.200.1
Kind regards.-
PS: Please don't forget to rate and mark as correct answer if this answered your question
Unfortunately, that does not resolve the rewriting of the source IP as my outside interface address.
handsy
Level 5
Level 5
I've resolved it:
object network int-map
host 10.92.200.1
object network ext-map
host 66.77.88.1
nat (inside,outside) source dynamic any interface destination static int-map ext-map
Very happy 🙂
