TFTP and PIX problem
fbtech
Community Member
I can not get a copy of my PIX config sent to our TFTP server. Other routers on our LAN can.
TFTP server is TFTPd32 by Ph Jounin running on a WinNT 4.0 SP6
PIX is configed like this.
tftp-server inside 192.20.6.8 pixwcimage
When I issue a 'wr net' of course the PIX trys, but this is the message on the TFTP server "Write request for file pixwcimage mode octet connections recieved from 192.20.6.8 on port 12345 Unexpected request3 from peer Returning EBADOP to peer Timeout while waiting for data block 0, file piximage. On the PIX I see a meesage "Illegal TFTP operation"
Once again I can copy configs from other routers on my network to this same TFTP server.
Any help would be appreciated
kendo.igor
Level 3
Level 3
Just to make sure it's not a compatibility issue between the TFPT server and PIX, try this TFTP server. I'm using it with PIX and it works fine:
http://support.3com.com/software/utilities_for_windows_32_bit.htm and then choose 3CDv2r10.zip. Make sure no other TFTP server is running on the same server at the same time.
Also, try using the following command instead:
write net 192.168.1.1:/backup/file1.txt
