The FDM Equivalent of selecting a public IP for PAT not directly connected to the outside interface.
cisco-noob
Any help with this is greatly appreciated. We just recently purchased the Firepower 1010. I am trying to specify a public IP address that is not directly connected to my outside interface. For example, in the 5540, you can select use PAT, then specify a public IP address like the image below. I have been stumped for over a week on how to do this. The answer is probably obvious. Thanks to anyone that can figure this out.
johnlloyd_13
Level 9
Level 9
hi,
you can go in FDM: policies > NAT.
select type: dynamic > under original packet: select the "inside" interface and source address (or create new).
under translated packet: select source address (or create new). leave the rest as "any".
LikeMyFloydPink
Use a /32  (255.255.255.255) subnet mask.  That may or may not be the answer - is it behind another router or something?  What is your use-case?
EDIT: Are you just trying to get past the wizard screen shown above?  I seriously don't know nor am I a NetSec guy. But if it is not directly connected and you are just trying to get it up and running, you could even use an RFC1918 address for the interim.
johnlloyd_13
Level 9
Level 9
hi,
cisco-noob
Thanks again!
I came up with the following rule and I hope that I understood you correctly. I will be deploying my configuration on Wednesday, hopefully, it goes well.
