Traceroute issue in ASA (not solved by other threads)
adrianopinaffo1
I know this has been going on for a long time, but I'm facing the traceroute issue in the ASA. Weirdly enough, I can reach the destination using traceroute with no problem, but I can't see the path to it. I pasted the result below.
I also checked my ASA configuration and the only setting that is not present is the "match any " for the "class-map class_default", because when I enter "class-map class_default" I get the following warning:
ASA(config)# class-map class-default
ERROR: % class-default is a well-known class and is not configurable under class-map
Can you guys help me? I posted below the tracert output and the concerned configuration. I can't find the misfit and I already checked most of the configuration forums.
C:\>tracert www.google.com
Tracing route to www.google.com [173.194.79.104]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  10.0.0.1
  2     *        *        *     Request timed out.
  3     *        *        *     Request timed out.
  4     *        *        *     Request timed out.
  5     *        *        *     Request timed out.
  6     *        *        *     Request timed out.
  7     *        *        *     Request timed out.
  8     *        *        *     Request timed out.
  9     *        *        *     Request timed out.
 10     *        *        *     Request timed out.
 11     *        *        *     Request timed out.
 12     *        *        *     Request timed out.
 13     *        *        *     Request timed out.
 14     *        *        *     Request timed out.
 15     *        *        *     Request timed out.
 16     *        *        *     Request timed out.
 17     *        *        *     Request timed out.
 18     *        *        *     Request timed out.
 19     *        *        *     Request timed out.
 20     *        *        *     Request timed out.
 21     *        *        *     Request timed out.
 22     *        *        *     Request timed out.
 23   212 ms   212 ms   212 ms  pb-in-f104.1e100.net [173.194.79.104]
Trace complete.
---Router configuration
icmp unreachable rate-limit 10 burst-size 5
object-group service ICMP_Return
 service-object icmp echo-reply
 service-object icmp time-exceeded
 service-object icmp traceroute
 service-object icmp unreachable
 service-object icmp6 echo-reply
 service-object icmp6 time-exceeded
 service-object icmp6 unreachable
access-list IF_outside_access_in remark ICMP Return
access-list IF_outside_access_in extended permit object-group ICMP_Return any any
access-group IF_outside_access_in in interface IF_outside
!--- This does not exit -> match any
class-map inspection_default
 match default-inspection-traffic
policy-map global_policy
 class class-default
  set connection decrement-ttl
service-policy global_policy global
Saqib Raza
I am assuming that 10.0.0.1 is the ip address on ASA?  if that is true you communication is not breaking on ASA since you see first hope in your trace route.... what is the next hop in path after ASA
Hello, it's not. 10.0.0.1 is my default gateway, a local router.
Something that is worth mentioning is, traceroute works for other ASA interfaces (DMZ). It only fails for the external interface.
Look:
c:\> tracert 10.0.100.50
Tracing route to webserver.corp.mycompany.com [10.0.100.50]
  1     3 ms     3 ms     2 ms  10.0.0.1
  2    <1 ms    <1 ms    <1 ms  10.0.0.2 <- This is the ASA
  3     1 ms     1 ms     1 ms  webserver.corp.mycompany.com [10.0.100.50]
Trace complete.
Any ideas?
Can you provide your configuration ?
Also , have you gone through this document to verify the configuration on the ASA device for the Trace route to run through the ASA device:-
http://www.cisco.com/c/en/us/support/docs/security/pix-500-series-security-appliances/15246-31.html
Please let me know from where are you trying the trace route ? Is is the Internal Host ?
Thanks and Regards,
Vibhor Amrodia
Hi Adriano,
I think you applied the set connection decrement under the wrong class map, let's try to do it with a new one and see if it works:
class-map TRACE
  match any
  class TRACE
You also need to reapply the default class map under the global policy map:
  class inspection_default
Aref
