Traffic Between INSIDE and DMZ Cisco ASA
cro130271
I need to be able to ping a DMZ host from an INSIDE host and visa versa. I have tried configuring a static nat as follows
static (INSIDE,DMZ) 192.168.10.0 192.168.10.0 netmask 255.255.255.0
I created an access-list called EXEMPT which permits any any. I know this is not the most secure option but at this point I just need it to work.
Any help and insight into this would be amazing. I have tried every guide on the internet and I understand it. I just don't know why it won't work.
Attached is the config of my device.
jj27
Either change your security level to 100 (or something higher than 50) on INSIDE, or put in the command "same-security-traffic permit inter-interface."
