trunk configuration between asa5505 and a 3750 switch
sansari
Greetings
I am trying to configure a trunk between the above two devices. I like to have vlan11 on ASA. Then I like to connect a host to my switch, and have it communicate with other devices in VLAN 11 or other vlans that reside on the ASA. Below is the config that I currently have. Would you please advise what I am missing?
ASA:
ciscoasa# show run interface Ethernet0/1
switchport access vlan 11
switchport trunk allowed vlan 10,12,101-103
switchport mode trunk
ciscoasa# show int vlan 11
Interface Vlan11 "inside", is down, line protocol is down
  Hardware is EtherSVI
        MAC address 0027.0d35.ad5c, MTU 1500
        IP address 10.1.1.254, subnet mask 255.255.255.0
  Traffic Statistics for "inside":
        2214171 packets input, 1172490074 bytes
        2051690 packets output, 755288140 bytes
        38384 packets dropped
      1 minute input rate 0 pkts/sec,  0 bytes/sec
      1 minute output rate 0 pkts/sec,  0 bytes/sec
      1 minute drop rate, 0 pkts/sec
      5 minute input rate 0 pkts/sec,  0 bytes/sec
      5 minute output rate 0 pkts/sec,  0 bytes/sec
      5 minute drop rate, 0 pkts/sec
ciscoasa# show run int vlan 11
interface Vlan11
nameif inside
security-level 100
ip address 10.1.1.254 255.255.255.0
On the 3750 I have:
interface GigabitEthernet2/0/1
end
As you can see vlan11 on the 5505 is down.
smsneteng
1. All Cisco switches are defaulted to dynamic desirable, so switchport mode trunk is not necessary, as long as the other side is set to trunk, the switch wiill trunk...which brings me to
2. The ASA must have the native VLAN set.
3. Looks like you're good to go
4. Nothing to do with VLAN access
5. As far as 1. goes, if a switchport were set as an access port without "switchport mode access", the trunking is still not shut off until you type "switchport mode access". To disabling dynamic desirable and permanently trunk no matter what (even if the other side is not trunking), you'd use "switchport trunk nonegotiate"
5 Replies 5
cadet alain
On your switch interface type: switchport mode trunk
Regards.
Alain.
Here is what I have in the ASA now..
switchport trunk native vlan 11
ciscoasa(config-if)# show run interface vlan
ciscoasa(config-if)# show run interface vlan 11
interface Vlan11
nameif inside
security-level 100
ciscoasa(config-if)# show int eth
ciscoasa(config-if)# show int ethernet 0/1
Interface Ethernet0/1 "", is up, line protocol is up
  Hardware is 88E6095, BW 100 Mbps
        Auto-Duplex(Full-duplex), Auto-Speed(100 Mbps)
        Available but not configured via nameif
        MAC address 0027.0d35.ad55, MTU not set
        IP address unassigned
        2559469 packets input, 1245515455 bytes, 0 no buffer
        Received 32039 broadcasts, 0 runts, 0 giants
        0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
        0 L2 decode drops
        21474852760 switch ingress policy drops
        2057559 packets output, 796341243 bytes, 0 underruns
        0 babbles, 0 late collisions, 0 deferred
        0 lost carrier, 0 no carrier
        0 rate limit drops
        0 switch egress policy drops
ciscoasa(config-if)# show int vlan11
Interface Vlan11 "inside", is up, line protocol is up
        2215503 packets input, 1173507560 bytes
        2054385 packets output, 755628198 bytes
        38388 packets dropped
      1 minute output rate 2 pkts/sec,  224 bytes/sec
      5 minute input rate 4 pkts/sec,  3390 bytes/sec
      5 minute output rate 3 pkts/sec,  642 bytes/sec
Here is what I have in the switch...
Current configuration : 99 bytes
end
interface Vlan11
no ip address
end
Switch(config-if)#do show int GigabitEthernet2/0/1
GigabitEthernet2/0/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is ec30.91dd.e981 (bia ec30.91dd.e981)
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 9
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 1000 bits/sec, 1 packets/sec
  5 minute output rate 1000 bits/sec, 2 packets/sec
     693818 packets input, 207178762 bytes, 0 no buffer
     Received 3018 broadcasts (1114 multicasts)
     449 runts, 0 giants, 0 throttles
     449 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 1114 multicast, 0 pause input
     1270324 packets output, 770436396 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Switch(config-if)#do show int vln
Switch(config-if)#do show int vlan
Switch(config-if)#do show int vlan11
Vlan11 is up, line protocol is up
  Hardware is EtherSVI, address is ec30.91dd.e9c2 (bia ec30.91dd.e9c2)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive not supported
  Last input 00:02:57, output 00:17:32, output hang never
     2846 packets input, 193668 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     67 packets output, 4288 bytes, 0 underruns
     0 output errors, 4 interface resets
Switch(config-if)#
But I still can not ping the vlan 11 ip address on the ASA from the switch, and I am not able to ping the server that is directly connected to the switch
hi,
you must give an IP address to int vlan11 on the switch also to ping the ASA or server .
Regards.
Alain.
Greetings-
The issue was the native vlan. Thanks to a knowledgeable CCIE friend. Appreciate the feedback from this group also.
smsneteng
