vlan and two outside interface
aung.htwe
Level 2
Level 2
Hi ,
Now my current asa 5510 is production as one inside interface (e0/1), one dmz(e0/2) interface and one outside interface(e0/0).
I want to add one more isp as outside 1 interface(e0/3).
Inside interface(e0/1) I will configure two vlans as one vlan for current network 192.168.1.0/24 and another one vlan for new network 192.168.10.0/24 to new isp with interface (e0/3).
Is it possible to work?
Aung
5 Replies 5
Jouni Forss
So you are basically looking into configuring 2 separate LAN and WAN connections. Both LANs will use their own WAN link to ISP also.
I am not that sure about this on the 8.2 (or lower) software level but have tested this on 8.4 - 9.1 software levels. Then again this is not officially supported by Cisco so you would never know if it suddenly stopped working.
Generally Cisco ASAs support having 2 ISP links but only 1 of them would be active at one given time.
To have 2 different LAN networks use their own WAN link requires special NAT configurations to accomplish that.
What is your current software level on the ASA?
- Jouni
Hi JouniForss,
Currently running version is ASA Version 8.2(5). That mean two ISP cannot active at the same time?
Aung
I have not tested or am not sure if there is really a way to accomplish this in the software you are running.
I have only tested this 8.4 - 9.1 software levels which use a completely different NAT configuration format compared to your software level.
Generally the CIsco ASA only support ISP failover. So only one ISP active at any given time. Some people might use Routing along with NAT configurations to enabled the use of both ISP but its not an officially supported setup.
On the newer softwares its easier to accomplish this with the NAT and that is the only thing I have tested.
- Jouni
Hi Jouni,
Thanks your answer, I will try with the current software 8.2 first. Could I know when I configure the two outside interface
for two internal seperate network so I have to add default router. Is it work for both internal network? Do i need to use static route network1 route to router 1 and network 2 route to router 2. ?
Ko Htwe
I dont really know if this is possible in the software level 8.2 as I have not tried. I would assume its not possible as the 8.4 - 9.1 softwares use completely different NAT configuration format.
I WOULD NOT suggest updating above 8.2 before familiriazing yourself with the changes that came to the NAT configuration format in the 8.3 software.
- Jouni
