vpn connection problem
kolawole1
Level 5
Level 5
I have two vpn configurations posted,
are they correct, will the 2 routers be able to establish vpn connection through the internet ?
mvsheik123
Level 11
Level 11
Looks like you are missing the hash. For more information check the link below.
http://www.cisco.com/en/US/products/hw/routers/ps221/products_configuration_example09186a008073e078.shtml
hth
MS
**Rate helpful posts**
