VPN Connection
Cash2106
Hi there,
Dear Technical team, i have configured vpn on windows server 2019, and i have created a access rule for specific ports in cisco asa, but whenever i am trying to connect to the vpn its giving me error and i am not able to login to the vpn dialup connection. the error i am getting is attached, please do check it and help me...
i have created the access rule as well in firewall which is given below access.jpg
32 Replies 32
Cash2106
Please help me.........
Do you have a static nat configured for your ADC-VPN-Machine object?
Provide your running configuration and the output of "show nat detail"
@Rob Ingram  yes NAT Rule is created, attached is a screen shot for it.
but PPTP use port number 1723 and one protocol 47 GRE, i have mentioned 1723 in the nat rule but i dont know how to add this 47 which is known as PPTP Pass through. natrule.jpg
You've not provided the information I asked for.
Try this link as it seems to relate to what you are trying to do https://www.petenetlive.com/KB/Article/0000009
@Rob Ingram  in access rule, there is already a access rule added in which interface outside is selected which i created myself and also showed to you in the screen shot, do i need to leave it like that or delete it and do according to the link you have given to me ?
please do acknowledge, i can share the details you have asked me for but is it possible if i can hide the IP's and then share it with you. please acknowledge.
@Rob Ingrami have configured all the steps mentioned in the link, but i am getting the same error ..
@Rob Ingram  when i have configured these two rules with internal interface, internet stopped working on the client machines so i had to delete them to keep the internet working. but the issue is sill not resolved, i am not able to connect the vpn
This vpn is pptp, if yes
do inspection pptp in asa global policy and see result.
@MHM Cisco Worldi have done it but still i am not able to connect to the vpn, i have attached screen shots of my configuration, if you can check and tell me if i am doing it right or not please.1.jpg2.jpgpptp.jpg3.jpg
@MHM Cisco World  so these settings are okay i just have to mentioned outside interface instead of the local machine IP rest these settings are okay to go ? am i right ?
@MHM Cisco World  did you check the screenshots, if you there is anything i am doing wrong or needs to do more steps can you please explain it to me ...
@MHM Cisco Worldi have already done these steps exactly mentioned in this article, but unfortunately my internet stopped working on all the client machines, so i had to revert these settings back
