Web Filtering Cisco ASA 5505 (Need Help Urgent)
Deepak.kumar111
Hello !
I m a network administrator, and i have been looking how to setup web filtering in a network, we are using cisco asa 5505 in many locations as a firewall and i have been looking for a way to block url such as facebook and streaming web sites since users are allowed to access to any website and they have been downloding stuff lately and i cant controll the bandwith!!
What u guys recommand !
Deepak Kumar
Network Admin
Metrologo
Email
Deepak.kumar@metroinfrasys.com
Websites
Contact No.
www.metroinfrasys.com
7838156663
Metro Infrasys Private Limited
|Plot No.190| Sector-6| IMT Manesar | Gurgaon| Haryana– 122050
11 Replies 11
Vibhor Amrodia
These are some of the available to bloc the Websites using the REGEX for HTTP(Not HTTPS):-
http://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/100535-asa-8x-regex-config.html
FQDN ACL:-
https://supportforums.cisco.com/document/66011/using-hostnames-dns-access-lists-configuration-steps-caveats-and-troubleshooting
Other than that you have to use an external URL filtering server which is the most feasible and recommended way.
Thanks and Regards,
Vibhor Amrodia
Dear Vibhor,
Thanks for your prompt response,
Kindly suggest an external URL filter server so that we can easily implement it on our sites for URL filtering .
hi,
you could elevate your existing 5505 and use CWS for URL filtering.
you'll just need to upgrade to ASA 9.x though.
see helpful link:
http://ccnpsecuritywannabe.blogspot.com/2015/09/cisco-cloud-web-security-cws-using-asa.html
Andres Vega
Hello Deepak
FirePOWER is the solution you need to filter either by category or url. Unfortunately the ASA 5505 does not support it, it is only for Next Generation Firewalls. But not everything are bad news, because Cisco offers it to deploy in virtual machines too. The FirePOWER module will provide you with statistics per user, host, in addition you will be able to analyze files looking for Malwares.
I have just one concern about how many locations do you have? And how the traffic flows toward internet. I mean is there a single internet connection per site? Or is everything centralized in one site?
Andres Vega
Dear Andres,
Kindly we are using a single internet connection on every sites, so what do you suggest if Firepower does not support ASA 5505 .
Kindly suggest the alternate solution for the same.
Deepak
Since you don't have centralized your internet connection it could be a little bit expensive to deploy. Because in that case you have to install a Virtual FirePOWER per location, the advantage to have a FirePOWER is that you would be able to perform filters by URL, Application, Signatures, by IP Address (Manual configured, or by Geolocation),  etc.
Other option could be forward the www traffic via VPN to the main location and centralized it in a single virtual FirePOWER.
My point there are multiple ways to achieve the deploy and have the best Next Generation IPS nowadays working for you and your company.
Note: For management you have to install a Virtual FireSIGHT Management console or get a physical Defense Center, in whatever option you choose you have to purchase the license to make it work as you want.
Deepak
Note: For management you have to install a Virtual FireSIGHT Management console or get a physical Defense Center, so whatever option you choose you have to purchase the license to make it work as you want.
Dear Andres,
Thanks For your prompt response,
Please tell me one thing how to purchase Virtual Firepower and what is correct model to support my firewall Cisco ASA 5505.
Is Fire Power support Web filtering (Like Sites Blocking Option) Available.tell me Installation process.
Regards:-
Deepak Kumar
Deepak
the only you need to purchase are the licenses, the software could be downloaded from the Cisco Website.
https://software.cisco.com/download/release.html?mdfid=286259687&catid=268438162&softwareid=286271056&release=SEU&relind=AVAILABLE&rellifecycle=&reltype=latest
https://software.cisco.com/download/release.html?mdfid=286259690&flowid=72310&softwareid=286271056&release=5.3.0.6&relind=AVAILABLE&rellifecycle=&reltype=latest
Licenses Comparision
http://www.cisco.com/c/en/us/support/docs/security/firesight-management-center/118396-technote-firesight-00.html
Virtual Installation Guide:
http://www.cisco.com/c/dam/en/us/td/docs/security/content_security/virtual_appliances/Cisco_Content_Security_Virtual_Appliance_Install_Guide.pdf?mdfid=282803424
Andres
Hi Andres,
Thank you for you help and i really appreciate you for this
but now I am in big trouble with costing for optimized solution of web filtering .Will CISCO-ASA 5505
with https://software.cisco.com/download/release.html?mdfid=286259687&catid=268438162&softwareid=286271056&release=SEU&relind=AVAILABLE&rellifecycle=&reltype=latest
be optimized solution with reference to cost and hardware comparatively New firewall with web filtering services.
Deepak,
The link you have posted is for Virtual FireSIGHT, it is the management console for FirePOWER modules, unfortunately your 5505 does not support FirePOWER Module, for that reason you have to think in a different alternative like for example deploy a virtual sensor, maybe that could works for you.
Andres
