What is Current control point in ASA
rami.saber
We have an ASA 5580 and under show cpu usage detailed there is the following:
Current control point elapsed versus the maximum control point elapsed for:
      5 seconds = 66.7%; 1 minute: 66.7%; 5 minutes: 66.7%
What does this indicate, I tried searching through cisco documents but didn't reach anything. After a sudden power faliuer slowness occured in the network, I found these values spike to 98% and I needed to confirm if it is related to the issue. We are know working on the standby ASA which has the above values. I am suspecting after rebooting the Active ASA it will work fine.
csaxena
Hello Rami,
This the output of show cpu usage, the below mentioned output suggests average CPU usage over the last 5s, 1min & 5min.
"5 seconds = 66.7%; 1 minute: 66.7%; 5 minutes: 66.7%"
This is because of no. of processes running on the firewall. You may see the processes running and individual CPU usage also on the firewall. CPU usage is usually more because of logging, snmp polling, threat detection, peak hours with excess traffic, etc.
Reply back with the version, output of "show cpu" & "show process" to help you with more info.
Hope this helps. Please reply back if you need any further assistance.
Chirag
P.S.: Please mark this thread as answered if you feel your query is answered. Do rate helpful posts.
Hi Chirag
Thanks for your reply
The version is 8.3(1).
What is the difference between show cpu usage
CPU utilization for 5 seconds = 1%; 1 minute: 1%; 5 minutes: 1%
And show cpu detailed,
When the issue occured the CPU utilization was normal but the current control point was in the 90's.
All above outputs are from the standby ASA,
