Which OID will help me to calculate jitter,delay.packet loss of voip networ
shivaniwagh
Help me to get the exact OID from rttMonMIB to calculate the delay,jitter & packet loss.
5 Replies 5
David Stanford
For Jitter have a look at the objects under the rttMonJitterStatsTable
For packetloss look at rttMonJitterStatsPacketLossSD and rttMonJitterStatsPacketLossDS
For delay:
rttMonLatestJitterOperOWSumSD rttMonLatestJitterOperOWSum2SD
rttMonLatestJitterOperOWMinSD
rttMonLatestJitterOperOWMaxSD rttMonLatestJitterOperOWSumDS rttMonLatestJitterOperOWSum2DS rttMonLatestJitterOperOWMinDS rttMonLatestJitterOperOWMaxDS rttMonLatestJitterOperNumOfOW
http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&step=2&submitClicked=true&mibName=CISCO-RTTMON-MIB#contents
But any one of the OID can be the data for delay??
for jitter I have used this rttMonLatestJitterOperMaxOfPositivesSD & rttMonLatestJitterOperMaxOfNegativesSD as well for rttMonLatestJitterOperMaxOfPositivesDS & rttMonLatestJitterOperMaxOfNegativesDS
I have one more query.I am not able to understand the Jitter Stats Table,as it gives two values.Ex.
snmpwalk $ip 1.3.6.1.4.1.9.9.42.1.3.5.1.12
Result:
cisco.ciscoMgmt.42.1.3.5.1.12.2.4214297322 : Counter: 148
cisco.ciscoMgmt.42.1.3.5.1.12.2.4214657322 : Counter: 11
Please help me to understand this,why it gives two values.?
Shivani
How many jitter operations have you configured? It looks like 2 as there are 2 different indices above -- 4214297322 and 4214657322
These each are the sum of number of all positive jitter values from packets sent from source to destination
Yes the MIB of rttMonJitterStats gives me the values for the two indices.I have no idea why its giving two.for latest it gives for only one..
Hi Shivani,
Some of these entries hold information for two hours, witht the statistics being grouped together over 60 minutes, hence the 2 sets of values.
The last value is the most current. These are then moved to the other entry and are removed from table after 120 minutes. i.e. a 'sliding window'.
HTH,
Mark
