benolyndav
Level 8
Level 8
Question5. We have 9300 2 switch stack for distribution layer, what options are there for redundant links is it just standard ether-channel.??
Answer
Leo Laohoo
yes
benolyndav
Level 8
Level 8
hunnymonster
Level 3
Level 3
Or two independent links and use spanning-tree to ensure that one is not forwarding (until the primary goes down)
Leo Laohoo
Distro layer switch and you don't want to use Etherchannel (going to the same switch)? Personally, I would not recommend this stunt. Does not even fall under "best practice" -- rather, this is one of those that falls under the category of "what NOT to do".
