ITA Terms
Community Member
How To Add A Port To A Vlan
Switch(config)#interface fastethernet 0/1
Switch(config-if)#switchport mode access
Switch(config-if)#switchport access vlan 3
--Sunil Khanna 08:03, 13 April 2008 (EDT)
yasirtoker
also this commands not solved
what is commands before this
if that a new router 881
thanks
Chetan
how to vlan configuration on cisco 300 24pp switch
joshgoldeneagle
Please keep in mind there could be cases of course, where you are trying to add a port to a vlan, and the port mode will not be "access".  If you are not careful, you could accidentally change a trunk port to an access port, with potentially dangerous results.
I think most people would not make this mistake, but just in case I wanted to let people know.
