pevaneyn
To avoid having too much client to client traffic on your network you can use 'ipv6 nd prefix default ...  off-link', don't forget to also add a route towards the interface on the router itself so:
interface GigabitEthernet0/0/0
      ipv6 address 2001:0db8:5150:F016::1/64
      ipv6 enable
      ipv6 nd reachable-time 600000
      ipv6 nd prefix default infinite infinite off-link
      ipv6 nd other-config-flag
      ipv6 nd router-preference High
      ipv6 nd ra lifetime 9000
      ipv6 nd ra dns server ...
      ipv6 dhcp server ...
      ipv6 verify unicast source reachable-via rx allow-default
ipv6 route 2001:0db8:5150:F016::/64 GigabitEthernet0/0/0
(this is a configuration optimized for wireless networks with very long timers)
This means that the client gets a default route, but no route towards the /64:
Internet6:
Destination                             Gateway                         Flags         Netif Expire
default                                 fe80::72ca:9bff:fe88:da83%en0   UGc             en0
::1                                     ::1                             UHL             lo0
And your client will only see the router as neighbour:
$ ndp -a -n
Neighbor                        Linklayer Address  Netif Expire    St Flgs Prbs
fe80::72ca:9bff:fe88:da83%en0   70:ca:9b:88:da:83    en0 23h59m57s S  R
So all the client to client traffic in the /64 will work, but will go via the router.
