Mark Malone
This may be useful to someone , put this script together it when it sees a phone in CDP it will auto configure the port for voice and data put port-security on it and dhcp snooping and bit of STP
This only works for phones , if you connect a switch the script will match nothing and not run it as a protection method not to just configure any CDP switch sees coming , you could tweak it if required
event manager applet Auto-Configure-Access-Ports-Voice&Data trap
description track and configure phone that comes up/up from cdp event
event neighbor-discovery interface regexp FastEthernet cdp add
action 0.1 comment "Verify Phone CDP neighbor connected"
action 0.2 regexp "(Phone)" "$_nd_cdp_platform" value
action 0.3 if $_regexp_result eq "1"
action 0.4 puts "match"
action 0.5 info type routername
action 0.6 cli command "enable"
action 0.7 cli command "config t"
action 0.8 cli command "default interface $_nd_local_intf_name"
action 0.9 cli command "interface $_nd_local_intf_name"
action 1.0 cli command "description $_nd_cdp_entry_name:$_nd_port_id"
action 1.1 cli command "switchport"
action 1.2 cli command "switchport mode access"
action 1.3 cli command "auto qos voip trust"
action 1.4 cli command "switchport voice vlan 196"
action 1.5 cli command "switchport access vlan 164"
action 1.6 cli command "spanning-tree portfast"
action 1.7 cli command "switchport port-security maximum 3"
action 1.8 cli command "switchport port-security maximum 2 vlan"
action 1.9 cli command "switchport port-security violation restrict"
action 2.0 cli command "switchport port-security aging time 1"
action 2.1 cli command "switchport port-security aging type inactivity"
action 2.2 cli command "switchport port-security"
action 2.3 cli command "ip dhcp snooping trust"
action 2.4 cli command "do write"
action 2.5 cli command "end"
action 2.6 syslog priority notifications msg CDP_Phone_Port_Auto_Configured_And_Copy_Run_Start_Completed
action 2.7 else
action 2.8 puts "nothing"
action 2.9 end
action 3.0 set _exit_status "0"
