TCC_2
Level 10
Level 10
Core Issue
Border Gateway Protocol (BGP) does not perform load balancing by default.
Resolution
Load sharing is a concept that allows a router to distribute the outgoing and incoming traffic among multiple paths. The paths are derived either statically or with dynamic protocols, such as RIP, EIGRP, OSPF, and IGRP. By default, Border Gateway Protocol (BGP) selects only a single best path and does not perform load-balancing.
For information on different load sharing scenarios using BGP and how to get BGP to select an alternate path, refer to Sample Configurations for Load Sharing with BGP in Single and Multihomed Environments.
show ip bgp neighbors {neighbor  address}
State is established
show ip eigrp neighbors
Neighbor exists in neighbor table
