fcolumbu
Integrated Routing and Bridging (IRB) Lab using the Cisco 5921 Embedded Services Router
This configuration is used with “Introduction to the Cisco 5921 Embedded Services Router v1” in dCloud.
1) Log into dCloud. Under Internet of Everything or Training, find the lab / demo, "Introduction to the Cisco 5921 Embedded Services Router v1”
2) Launch a dCloud session using this lab and follow the instructions to connect using the AnyConnect client. Do the actual AnyConnect access after step 4 as this will allow time for the dCloud session to start. Please be sure to specify "NOW" as the launch time. This lab takes approximately 5 minutes to be ready for use.
3) Begin by looking at the configuration view links for the intended changes to the router configurations to implement the desired feature. The changes are differentiated from the rest of the configuration using Boldface Orange text.
Cisco dCloud Lab - Integrated Routing and Bridging (IRB) on the 5921 ESR - c5921_ubuntu32_1 - View
https://communities.cisco.com/docs/DOC-63988
4) Go to the following DevNet Community links and download the configurations to be used in this lab. Please use the download links for this.
Cisco dCloud Lab - Integrated Routing and Bridging (IRB) on the 5921 ESR - Download
https://communities.cisco.com/docs/DOC-62561
5) On  c5921_ubuntu32_1  shutdown the following port ethernet 0/0.
6) Remove the IP addresses from the following ports: ethernet 0/1, 0/2, 0/3. (no ip addr)
7) Please add all the highlighted (bold orange) commands in the configuration.
8) After a waiting few seconds for OSPF to re-converge, you should see the following routing table  on c5921_ubuntu32_1:
*Dec  1 05:07:08.310: %OSPF-5-ADJCHG: Process 100, Nbr 10.0.0.121 on BVI1 from LOADING to FULL, Loading Done
c5921_ubuntu32_1#sh ip rou
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       a - application route
       + - replicated route, % - next hop override
Gateway of last resort is 198.18.134.120 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 198.18.134.120
      10.0.0.0/32 is subnetted, 2 subnets
C        10.0.0.120 is directly connected, Loopback0
O        10.0.0.121 [110/2] via 172.23.2.2, 00:00:00, BVI1
      172.23.0.0/16 is variably subnetted, 5 subnets, 2 masks
O        172.23.1.0/24 [110/2] via 172.23.2.2, 00:00:00, BVI1
C        172.23.2.0/24 is directly connected, BVI1
L        172.23.2.1/32 is directly connected, BVI1
O        172.23.3.0/24 [110/2] via 172.23.2.2, 00:00:00, BVI1
O        172.23.4.0/24 [110/2] via 172.23.2.2, 00:00:00, BVI1
C     198.18.128.0/18 is directly connected, Ethernet1/0
      198.18.134.0/32 is subnetted, 1 subnets
L        198.18.134.131 is directly connected, Ethernet1/0
9) Notice that since we set the ip address of BVI1 to 172.23.2.1 the neighbor relationship is established via the corresponding subnet on c5921_ubuntu32_2 in this case 172.23.2.2.
If we have ethernet 0/1, 0/2, 0/3 for c5921_ubuntu32_1 bridging at layer 2 and then routing, effectively the same as using a switching HWIC in one of the ISR's, we should be able to set the ip address of BVI1 to subnet 3 or 4 and our Layer 3 should re-converge.
Go ahead and try changing BVI1 to 172.23.3.1 and observe the following:
c5921_ubuntu32_1(config)#interface BVI1
c5921_ubuntu32_1(config-if)#ip address 172.23.3.1 255.255.255.0
*Dec  1 05:08:25.454: %OSPF-5-ADJCHG: Process 100, Nbr 10.0.0.121 on BVI1 from FULL to DOWN, Neighbor Down: Interface down or detached
*Dec  1 05:08:30.251: %OSPF-5-ADJCHG: Process 100, Nbr 10.0.0.121 on BVI1 from LOADING to FULL, Loading Done
c5921_ubuntu32_1(config-if)#do sh ip rou
O        10.0.0.121 [110/2] via 172.23.3.2, 00:00:30, BVI1
O        172.23.1.0/24 [110/2] via 172.23.3.2, 00:00:30, BVI1
O        172.23.2.0/24 [110/2] via 172.23.3.2, 00:00:30, BVI1
C        172.23.3.0/24 is directly connected, BVI1
L        172.23.3.1/32 is directly connected, BVI1
O        172.23.4.0/24 [110/2] via 172.23.3.2, 00:00:30, BVI1
10) Lastly, try changing BVI1 to 172.23.4.1 and observe the following:
c5921_ubuntu32_1(config-if)#ip address 172.23.4.1 255.255.255.0
*Dec  1 05:09:34.532: %OSPF-5-ADJCHG: Process 100, Nbr 10.0.0.121 on BVI1 from FULL to DOWN, Neighbor Down: Interface down or detached
*Dec  1 05:09:39.374: %OSPF-5-ADJCHG: Process 100, Nbr 10.0.0.121 on BVI1 from LOADING to FULL, Loading Done
O        10.0.0.121 [110/2] via 172.23.4.2, 00:00:10, BVI1
O        172.23.1.0/24 [110/2] via 172.23.4.2, 00:00:10, BVI1
O        172.23.2.0/24 [110/2] via 172.23.4.2, 00:00:10, BVI1
O        172.23.3.0/24 [110/2] via 172.23.4.2, 00:00:10, BVI1
C        172.23.4.0/24 is directly connected, BVI1
L        172.23.4.1/32 is directly connected, BVI1
Note: Here is one more way to view it:
c5921_ubuntu32_1#sh ip ospf neighbor
Neighbor ID     Pri   State           Dead Time   Address         Interface
10.0.0.121        1   FULL/DR         00:00:36    172.23.4.2      BVI1
Conclusions:
This lab allowed you to verify that a particular Cisco IOS feature is supported on the 5921 ESR.
It introduced you to the DevNet community for IoT Embedded and specifically showed that there is a space to share and to post useful 5921 configurations and other companion code.
dCloud allowed you to launch in a few minutes what would take hours to build in your own lab.
