rgiorgi
Overview
This demonstration provides Cisco Field and Channel Partners an easy, scalable way to demonstrate the Cisco Identity Services Engine (ISE) security solution. Not only is the experience more streamlined, but it automates and simplifies access control and security compliance for wireless networks. Cisco dCloud helps you to easily and instantly use an access point and/or endpoint router to demonstrate this scalable Cisco solution.
This Cisco ISE solution will includes the following use cases:
  • Guest Access Management – simple quick and easy hotspot, self-registered and sponsored guests!
  • BYOD – onboarding of employee devices using ISE for native supplicant and certificate provisioning
  • Secure Access  - 802.1x differentiated access depending on user groups
  • Device Admin (TACACs) – RBAC controls of Network Access Device configurations
For more information, click here: Cisco ISE 2.3 Mobility Deep Dive v1
Scenarios
  • Scenario 1: Guest Internet Access with Hotspot
  • Scenario 2: Self-Registered Guest Access with Sponsor Approval
  • Scenario 3: Sponsored Guest Access
Device Onboarding and Management
  • Scenario 1: Device Onboarding for BYOD
  • Scenario 2: Device Management
Secure Access
  • Scenario 1: Secure Access (802.1x) Differentiated Access
Device Administration
  • Scenario 1: Device Administration
  • Scenario 2: Analyzing Device Administration
Requirements
RequiredOptional
  • Preferred Endpoint Router
    • 819W router, registered and configured for Cisco dCloud
    • Cisco Aironet Series Access Point (3000, 2000, or 1000 series)
  • Laptop
  • User Devices
    • Tablet
    • Smartphone
    • Laptop
  • Access Point (must support WLC 8.5 code)
  • Cisco AnyConnect®
Components
  • Cisco Identity Services Engine (ISE) 2.3
  • Microsoft Active Directory-Windows 2008 R2
  • Microsoft Exchange 2010-Windows 2008 R2
  • Cisco Virtual Wireless Controller (vWLC) 8.5
  • Cisco Virtual Cloud Services Router (CSRv)
Topology
