I'm running Prime Infrastructure 3.7 and the inline upgrade failed as shown below.=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2021.02.24 17:04:19 =~=~=~=~=~=~=~=~=~=~=~=application upgrade PI-Upgrade-36x_37x_to_3.8.0.0.310.tar.gz CCFTPSave the current ADE-OS runnin...
view more
I am deploying Cisco ISR 4300 Series IOS XE Universal which shall embed some IP SLA feature from the web information.I would like to ask what feature are include for Cisco ISR 4300 Series IOS XE Universal without equip APP license?Thanks for the supp...
view more
Buen día, estimados. Queremos pedir de su amable apoyo y de sus opiniones sobre el siguiente incidente que tenemos actualmente: Tenemos dos switches modelo 4500-X conectados en VSS mediante dos fibras ópticas, dichos switches representan los COR...
view more
Hello, I might be missing some basics on how VRFs work. But Following is configuration GNS3 (question at the bottom, image attached): PC4 -->(G2/0) R1 (G1/0.2)---> (G1/0.2) R2 PC4: ip 10.1.1.10 255.255.255.0 10.1.1.1 R...
view more
Hi, I'm trying to configure a 93180 an allow SCP. I configured an IP 1.1.1.1/24 on the port. On my workstation, I put 1.1.1.2/24. I can ping the switch from the WS but I can't ping the WS from the swtich. I added a default rou...
view more
