imbashir
Cisco® Software-Defined Access (SD-Access) enables customers to ease their network management worries, it gives you a single network fabric, from the edge to the cloud. You can set policy-based automation for users, devices, and things. Provide access to any application, without compromising on security. All while gaining awareness of what is hitting your network. And with automatic segmentation of users, devices, and applications, you can deploy and secure services faster.
Cisco SD-Access Solution Design Guide (CVD):
https://www.cisco.com/c/en/us/td/docs/solutions/CVD/Campus/cisco-sda-design-guide.html
Cisco DNA Center & ISE Management Infrastructure Deployment Guide:
https://www.cisco.com/c/en/us/td/docs/solutions/CVD/Campus/cisco-dnac-ise-deploy-guide.html
RuthRussell7604
I've chosen the following components for create a network- wire& wireless (Academic, practice), would like to know about proficiency, stability. What is the best choices if need to be updated.
Topology and Routers (C931-4P- Configuration for Wire and Wireless), second part Wiring connect Items (Cables & Connectors (CAT-E 6-with RJ455), Proposed Networking and internet working Devices (Firewalls (Firepower 2110)), and WAN design(Access point devices- Aironet 3800e AP-Wire and Wireless adapters), and  at the last part hardware (Dell- Precision 3430 computers).
The size of this network is medium , various rooms , about (7), users total = 200
Thanks for your help.
RRussell
marek.golha
isnt there also a video to the slides? It would be very helpful.
Thanks.
Marek
Adis Cato
It would be awesome if this document could be updated with current features and details. I understand that the design approach is similar, but the DNA-C and ISE versions described here are obsolete, and there are several new features that need to be described...
