TCC_2
Level 10
Level 10
Resolution
You can have multiple Switched Port Analyzer (SPAN) sessions configured at the same time. But there are certain restrictions while configuring additional SPAN sessions.
For more information on SPAN and Remote SPAN (RSPAN) session limits, refer to these documents:
For multiple SPAN sessions, add the create keyword at the end when configuring the additional session, as shown:
For configuring the first SPAN session:
6509> (enable) set span 3/1 2/1
Destination      Port 2/1
Admin Source     Port 3/1
Oper Source      Port 3/1
Direction        transmit/receive
Incoming Packets disabled
Learning         enabled
Multicast        enabled
Filter           -
Status           active
For configuring the additional SPAN session:
6509> (enable) set span 3/5 3/10 create
Destination      Port 3/10
Admin Source     Port 3/5
Oper Source      Port 3/5
Learning         enabled
Multicast        enabled
Filter           -
Status           active
To verify the multiple SPAN sessions:
6509> (enable) show span
Learning         enabled
Multicast        enabled
Filter           -
Status           active
Learning         enabled
Multicast        enabled
Filter           -
Status           active
Total local span sessions  2
