Tim Glen
Table of Contents
Summary
Here we will go over the configuration needed for MACsec Switch to Switch using EAP-TLS for authentication. MKA and MACsec are implemented after successful authentication using the certificate-based MACsec. Please see the MACsec History and Terminology for a basic understanding of where MACsec came from, the cipher suites and encryption methods, and acronym definitions. While I am using Switch to Switch this can also be used for Router <-> Switch or Router <-> Router as long as MACsec is supported on the interfaces.  Configuring MACsec on NX-OS is likely to be different from these examples. When switch-to-switch MACSec is enabled, all traffic is encrypted, except the EAP-over-LAN (EAPOL) packets.
In these examples, I’m using two Catalyst 9300 switches, both running IOS XE 17.3(4).
This will be the one in a series of documents I write on MACsec. Some of the other topics I’ll be writing are…
Creating a CSR, Authenticating a CA and Enrolling Certificates on IOS XE
Configuring MACsec Switch to Switch with PSK Authentication
Configuring Certificate Based MACsec Switch to Switch with ISE Authentication
Configuring MACsec Switch to Host with ISE and Cat 9K
Problem Statement
Typically businesses trust traffic that is traversing cable.  We need to stop trusting the cable, there are inexpensive devices that can easily be inserted into the path that can help attackers perform meddler-in-the-middle attacks. The Zero Trust Model should extend to the network medium and in wireless it does.   We need to start encrypting traffic that traverses our wired ethernet networks, MACsec does this with little cost, little overhead and at wire speed.
Requirements
  • Certificates on each IOS XE device must be issued by the same CA
  • Certificates can be obtained using SCEP or manual enrollment
  • Certificates must contain the following X509 Usages
    • Digital Signature
    • Key Encipherment
  • Certificates must contain the following Extended Key Usages
    • Server Auth
    • Client Auth
  • IOS XE 17.3(4) is used for this lab and is recommended. Earlier versions may work. MACsec was introduced into IOS XE in 16.5.1a
  • Certificate-based MACsec is supported only if the access-session is configured as closed or in multiple-host mode.
  • Switch name, Domain Name, DNS IP Addresses & NTP
  • IBNS 2.0
Network Diagram
Configuration Steps
Obtain Certificates for both Switches
First we need identity certificates on both our switches. Please follow the following document I wrote.
AAA Config
I prefer to use Named Lists in my AAA Config because it creates very prescriptive results.
conf t
aaa new-model
aaa local authentication MACSEC-UPLINK authorization MACSEC-UPLINK
aaa authorization credential-download MACSEC-UPLINK local
aaa authentication dot1x MACSEC-UPLINK local
aaa authorization network MACSEC-UPLINK local
end
Create Local Username for 802.1x Authentication
This username will be referenced in the dot1x Cred Set section below.
This username does not need a password.
We are using local authentication.  When this user is successfully authenticated the attribute-list is applied. It's then that the MUST-SECURE attribute is applied to the MACsec Network Link.
conf t
aaa attribute list MUST-SECURE
attribute type linksec-policy must-secure
username usr-macsec aaa attribute list MUST-SECURE
end
Create a policy map for MACsec Uplink
First off, IBNS2.0 rocks!  The flexibility is just off the charts. If your configuration is not already using IBNS 2.0 you will be prompted to enable it,  IBNS 1 is NOT supported so you must enable IBNS 2.0.
This is the policy-map that we will apply to interfaces that connect the switches.
The policy-map should be somewhat self explanatory.
Authenticate using dot1x and use the AAA AuthC list named MACSEC-UPLINK. Remember we configured that in a previous step.
In the event of dot1x failure, try again!
When Authentication is successful implement a standard service template that enabled the 'MUST SECURE' attribute.
Note: if you don't already have IBNS 2 enabled you will be prompted to enable it in this section.
conf t
policy-map type control subscriber DOT1X-MUST-SECURE-UPLINK
event session-started match-all
10 class always do-until-failure
10 authenticate using dot1x aaa authc-list MACSEC-UPLINK authz-list MACSEC-UPLINK both
event authentication-failure match-all
10 terminate dot1x
20 authentication-restart 10
event authentication-success match-all
10 activate service-template DEFAULT_LINKSEC_POLICY_MUST_SECURE
end
Configure EAPTLS AuthC Profile and 802.1x Credential Set
In this section we enable system wide dot1x and create the authentication profiles.
I'm referencing the trustpoints in my own configuration.
Make sure the pki-trustpoint trustpoint in your configuration references YOUR trustpoint!
conf t
dot1x system-auth-control
eap profile EAP-PROFILE
method tls
pki-trustpoint bot-sw
dot1x credentials DOT1X-CREDS
username usr-macsec
end
Configure the Switchport for VLAN Trunking, dot1x & MACsec Network Link
conf t
interface g1/0/3
switchport
switchport mode trunk
macsec network-link
authentication periodic
authentication timer reauthenticate 1800
access-session host-mode multi-host
access-session closed
access-session port-control auto
dot1x pae both
dot1x supplicant eap profile EAP-PROFILE
dot1x authenticator eap profile EAP-PROFILE
service-policy type control subscriber DOT1X-MUST-SECURE-UPLINK
end
Verification
show crypto pki certificates verbose trustpoint
This will show all possible information about the certificate.
show access-session interface g1/0/3 details
This shows a successful dot1x authentication & authorization.  This is the first thing to check.   If dot1x authentication fails then MKA will never start.
show dot1x int g1/0/3 details
This shows some basic dot1x details.
show policy-map type control subscriber DOT1X-MUST-SECURE-UPLINK detail
This shows specifics on the policy-map, including execution, hit counts.
show mka session interface g1/0/3
CKN or Connectivity Key Name is a container for storing the Connectivity Association Key. The CKN is the same on both peers. The CKN is transmitted across the wire in clear text to the peer to assist the peer in validating the CAK.
show mka session interface g1/0/3 details
Use this command to deep dive into the MKA session status.
show mka policy
Find the policy you are looking for if it is not the Default Policy.  Assure the interface in question has the proper policy applied.
show macsec interface g1/0/3
Use this command to deep dive into the MACsec session statistics.
show authentication brief
show history all
show platform pm port-data GigabitEthernet1/0/3
Troubleshooting
! Debug crypto pki is not supported on C9200
debug crypto pki messages
debug crypto pki transactions
debug crypto pki validation
debug macsec
debug mka errors
debug mka events
debug mka linksec-interface
! *** be warned this can quickly overrun the buffer
debug mka macsec-interface
References
Cisco IOS XE Command Reference Guides for Access and Edge Routers
Cisco IOS XE Security Configuration Guide - MACsec Encryption
M@rco
Frequent Visitor
Frequent Visitor
Hello Tim,
how can you use SHOULD-SECURE with a PSK?
