cjaffree2
Community Member
I have a 3560-48PS doing layer 3 switching and have a single VRF configured on it.  The VRF contains two SVI's - one is configured with a static IP address and the other is configured to obtain its IP address via dhcp.  The dhcp address is obtained, but the default route does not show up in the global or the VRF forwarding tables.  I'm looking for a little insight on whether I'm missing something or if this is due to a bug.
I've dropped in configuration and version information below.  Any help is greatly appreciated.
dsl-test(config-if)#no shut
3d01h: DHCP: DHCP client process started: 10
3d01h: RAC: Starting DHCP discover on Vlan30
3d01h: DHCP: Try 1 to acquire address for Vlan30
3d01h: DHCP: allocate request
3d01h: DHCP: Lease server or giaddr changed. Removing lease entry for : 192.168.1.1 (10)
3d01h: DHCP: deleting entry 5714690 192.168.1.1 from list
3d01h: DHCP: new entry. add to queue
3d01h: DHCP: SDiscover attempt # 1 for entry:
3d01h: DHCP: SDiscover: sending 296 byte length DHCP packet
3d01h: DHCP: SDiscover 296 bytes
3d01h:             B'cast on Vlan30 interface from 0.0.0.0
3d01h: DHCP: Received a BOOTREP pkt
3d01h: DHCP: offer received from 192.168.1.109
3d01h: DHCP: SRequest attempt # 1 for entry:
3d01h: DHCP: SRequest- Server ID option: 192.168.1.109
3d01h: DHCP: SRequest- Requested IP addr option: 192.168.1.1
3d01h: DHCP: SRequest placed lease len option: 600
3d01h: DHCP: SRequest: 314 bytes
*Mar  3 20:27:00 EST: %LINK-3-UPDOWN: Interface Vlan30, changed state to up
*Mar  3 20:27:00 EST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan30, changed state to up
3d01h: DHCP Client Pooling: ***Allocated IP address: 192.168.1.1
3d01h: Allocated IP address = 192.168.1.1  255.255.255.0
*Mar  3 20:27:01 EST: %DHCP-6-ADDRESS_ASSIGN: Interface Vlan30 assigned DHCP address 192.168.1.1, mask 255.255.255.0, hostname dsl-test
^Z
dsl-test#sh ip rou
*Mar  3 20:27:06 EST: %SYS-5-CONFIG_I: Configured from console by cjaffree on vty0 (10.2.36.124)te vrf dsl
Routing Table: dsl
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
     172.31.0.0/24 is subnetted, 1 subnets
C       172.31.255.0 is directly connected, Vlan1050
C    192.168.1.0/24 is directly connected, Vlan30
dsl-test#sh int vlan30
Vlan30 is up, line protocol is up
  Hardware is EtherSVI, address is 0013.c304.f9c1 (bia 0013.c304.f9c1)
  Internet address is 192.168.1.1/24
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not supported
  Last input 00:00:29, output 00:00:26, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     151078 packets input, 9136117 bytes, 0 no buffer
     Received 0 broadcasts (9 IP multicasts)
     6396 packets output, 2141012 bytes, 0 underruns
     0 output errors, 8 interface resets
dsl-test#
dsl-test#
dsl-test#
dsl-test#
dsl-test#
dsl-test#
dsl-test#
dsl-test#sh dhcp
dsl-test#sh dhcp ?
  lease   Show DHCP Addresses leased from a server
  server  Show DHCP Servers we know about
dsl-test#sh dhcp le
dsl-test#sh dhcp lease ?
  interface  Show DHCP information on one interface
  |          Output modifiers
  <cr>
Temp IP addr: 192.168.1.1  for peer on Interface: Vlan30
Temp  sub net mask: 255.255.255.0
   DHCP Lease server: 192.168.1.109, state: 5 Bound
   DHCP transaction id: 1390
   Lease: 600 secs,  Renewal: 300 secs,  Rebind: 525 secs
Temp default-gateway addr: 192.168.1.254
   Next timer fires after: 00:04:20
   Retry count: 0   Client-ID: cisco-0013.c304.f9c1-Vl30
   Client-ID hex dump: 636973636F2D303031332E633330342E
                       663963312D566C3330
   Hostname: dsl-test
dsl-test#sh run
Building configuration...
Current configuration : 5241 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log datetime localtime show-timezone
service password-encryption
hostname dsl-test
boot-start-marker
boot-end-marker
enable secret 5 xxxxxxxxxxxx
username ts privilege 7 password 7 xxxxxxxxxx
aaa new-model
aaa authentication login default local group tacacs+
aaa authorization exec default local group tacacs+
aaa session-id common
clock timezone EST -5
clock summer-time EDT recurring
system mtu routing 1500
vtp domain dsl-test
vtp mode transparent
no ip subnet-zero
ip routing
ip domain-name usa.ts.com
ip dhcp excluded-address 172.31.255.1
ip dhcp pool dsl
   vrf dsl
   network 172.31.255.0 255.255.255.0
   subnet prefix-length 24
   dns-server 10.1.10.8 10.1.10.11
   domain-name tsguest.ts.net
   lease 0 1
   renew deny unknown
   remember
ip vrf dsl
rd 100:10
crypto pki trustpoint TP-self-signed-3271883136
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3271883136
revocation-check none
rsakeypair TP-self-signed-3271883136
crypto pki certificate chain TP-self-signed-3271883136
certificate self-signed 01
  30820259 308201C2 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33323731 38383331 3336301E 170D3933 30333031 30303031
  30395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 32373138
  38333133 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100BA42 0F20F7BA 06CE9B93 65DCDA9D 8C853299 1A2EF3DA C01DC2C7 28F86B67
  37B3E8EC 2D733901 91A046D4 FA3FBF1E 278AA266 5403D259 553BBC93 92B6448B
  2871C610 9A1DC9BC 03E622E7 7D3CF3BA 036F80C9 713CA148 BDD16D81 74829753
  2FC06E3E D12F4E5C B374EEC9 1CA2FD71 93DA0E90 FFB6FC08 CF924A56 D3873B25
  1C690203 010001A3 8180307E 300F0603 551D1301 01FF0405 30030101 FF302B06
  03551D11 04243022 82206473 6C2D7465 73742E75 73612E74 726F7574 6D616E73
  616E6465 72732E63 6F6D301F 0603551D 23041830 16801405 C5054924 52CCBEDF
  2D6FE4C1 82492F31 D2C69B30 1D060355 1D0E0416 041405C5 05492452 CCBEDF2D
  6FE4C182 492F31D2 C69B300D 06092A86 4886F70D 01010405 00038181 00A091D2
  15555276 27626FC2 26C82A5E 0F349002 18F52D0F D39B903D D551DAEF C65E2746
  61F882D4 06106E2C DDAB4331 AE068884 F349EDE2 B6558830 7DD3BEDE 2916E6F6
  8E66B26A B1E1EEB5 EBB01EC8 60D20311 A70EBCE7 E48F779D CFE4F47E A0E4F349
  06150DB0 713EBED2 2B7832AF C5EBC305 980980FF 713BA334 3766E208 30
  quit
spanning-tree mode pvst
spanning-tree portfast bpdufilter default
no spanning-tree optimize bpdu transmission
spanning-tree vlan 1-1000 priority 24576
vlan internal allocation policy ascending
vlan 30
name dsl-test outside
vlan 136
name FL36_Vlan
vlan 1050
name dsl-inside
vlan 1051
name dsl-outside
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
switchport mode trunk
spanning-tree bpdufilter enable
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface FastEthernet0/25
interface FastEthernet0/26
interface FastEthernet0/27
interface FastEthernet0/28
interface FastEthernet0/29
interface FastEthernet0/30
interface FastEthernet0/31
interface FastEthernet0/32
interface FastEthernet0/33
interface FastEthernet0/34
interface FastEthernet0/35
interface FastEthernet0/36
interface FastEthernet0/37
interface FastEthernet0/38
interface FastEthernet0/39
interface FastEthernet0/40
interface FastEthernet0/41
interface FastEthernet0/42
interface FastEthernet0/43
interface FastEthernet0/44
interface FastEthernet0/45
switchport access vlan 30
switchport mode access
interface FastEthernet0/46
interface FastEthernet0/47
interface FastEthernet0/48
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface Vlan1
no ip address
shutdown
interface Vlan30
ip vrf forwarding dsl
ip address dhcp
interface Vlan136
ip address 10.2.36.4 255.255.255.0
interface Vlan1050
description DSL-Test Inside
ip address 172.31.255.1 255.255.255.0
no ip proxy-arp
ip classless
ip route 0.0.0.0 0.0.0.0 10.2.36.1
ip http server
ip http secure-server
ip sla enable reaction-alerts
tacacs-server host 10.1.10.27
tacacs-server directed-request
tacacs-server key 7 xxxxxxxxxxxxx
line con 0
line vty 5 15
end
