Paul Zimmerman
Difference between USGMII and USXGMII:
  • USGMII is used for 8x10M/100M/1GE network ports, with each port maximum speed of 1GE. USXGMII-Single  Port version can be used to support ONE network port with 10M/100M/1G/2.5G/5G/10G data rates
  • USGMII is used for 10M/100M/1G network port speeds, while USXGMII support 10M/100M/1G/2.5G/5G/10G.
  • There are two types of USXGMII: USXGMII-Single Port and USXGMII-Multiple Ports.
  • USGMII and USXGMII provide the same capabilities using the packet control header.
Why USGMII is better than SGMII/QSGMII:
  • SGMII supports a single 10M/100M/1G network port over 1,25Gbps SERDES between MAC and PHY, while QSGMII supports four 10M/100M/1G network ports over 5Gbps SERDES between MAC and PHY.
  • USGMII supports eight 10M/100M/1G network ports over 10Gbps SERDES between MAC and PHY. This is most critical for high density switches and PHY. USGMII also provides packet control header to pass control/status between PHY and MAC. One of the application is Time-Stamp for PTP and 802.1AS.
youcisco
Hi Paul,
How can we get the USXGMII specification EDCS-1467841 revision 1.4?
linusti
For the latecomers...you need to be a member of this community and go into the ARCHIVED documents section of the network programming- it's no longer, "relevant," but they have thoughtfully archived it under USXGMII there.
It covers, in large, the spec that most care about.  It's kind of shameful that Cisco doesn't do a better job since they fostered the standard in the first place.
Paul Zimmerman
Thanks, @linusti ... you are right, the content is still available here:
https://developer.cisco.com/site/usgmii-usxgmii/
But since it is archived, you have to be logged into the developer.cisco.com site.
linusti
Yep.  And it needed to be shared.  You kind of need to have this document to understand some of the Specification if you're implementing a system using it between USXGMII so you don't foot-gun yourself with some aspects of it.
Happy to have helped the community here.  Even if I've now found out that we DID foot-gun ourselves on gear...  X-D
linusti
And thanks IS given to Cisco for their keeping it around to able to be found.  Seriously...it's appreciated.
jkaushik
May I know if USXGMII-M or USXGMII-4P is the same interface?
Can MAC as USXGMII-M and PHY as USXGMII-4P interface will work?
fxgang22
I have a question. xilinx's vivado has qsgmii type ip and qsgmii mode transceiver, but no usgmii mode transceiver. Can I set my qsgmii mode transceiver to 10Gps to use as a usgmii mode transceiver? thank you!
