TCC_2
Level 10
Level 10
Core Issue
When a file is deleted in the Class B Flash file system, the memory space occupied by the deleted file is not released until you issue the squeeze { flash: | slot0: } command.
Resolution
To release the memory space occupied by a deleted file, issue the squeeze { flash: | slot0: } command, as shown in this output:
Router# squeeze slot0:
Squeeze operation may take a while. Continue? [confirm]
squeeze in progress...
sssssssssssssssssssssssseeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
If the squeeze command is not available, you can issue the erase command.
The erase command should not be issued on the Flash occupied by the Cisco IOS  routers, as shown in this output:
Router# erase slot0:
Erasing the slot0 filesystem will remove all files! Continue? [confirm]
Current DOS File System flash card in slot0: will be formatted into Low
End File System flash card! Continue? [confirm]
Erasing device...
eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
...erased
Erase of slot0: complete
