TCC_2
Level 10
Level 10
Core Issue
The established keyword indicates that packets belong to an existing connection if the Transmission Control Protocol (TCP) datagram has the Acknowledgment (ACK) or Reset (RST) bit set.
Resolution
To resolve this issue, perform these steps:
  1. Permit all established connections through the Access Control List (ACL) by using the established keyword.
    This is an example:
    access-list 100 permit tcp any any established
    For more information, refer to the Allow Only Internal Networks to Initiate a TCP Session section of Configuring Commonly Used IP ACLs.
    2. Ensure that Domain Name System (DNS) traffic (User Datagram Protocol [UDP] port 53) is permitted through the ACL.
       Otherwise, users will not be able to browse the Internet by domain name.
