TCC_2
Level 10
Level 10
Resolution
A basic and required task for configuring IP is to assign IP addresses to network interfaces. Doing so enables the interfaces and allows communication with hosts on those interfaces using IP. Associated with this task are decisions about subnetting and masking the IP addresses.
For information on IP addressing and subnetting, refer to these documents:
