Joe Clarke
It is very easy to send email messages using EEM.  Often times, it is sufficient to simply include CLI output or other messages in the body of the email.  However, some output may be quite large, or you may have a need to send binary attachments (e.g. Embedded Packet Capture files).  In those cases, it would be better to use MIME encoding, and add the data as file attachments.  Here is a short proof-of-concept EEM script that demonstrates how to do this.
::cisco::eem::register_event_none
namespace import ::cisco::eem::*
namespace import ::cisco::lib::*
# First, create the headers and body of your message
set email_body_pre "Mailservername: $_email_server
To: $_email_to
Cc:
Subject: Email from Router $_router_name
MIME-Version: 1.0
Content-type: multipart/mixed; boundary=\"EEM_email_boundary\"
\n--EEM_email_boundary\n
Content-Type: application/octet-stream
Content-Transfer-Encoding: Base64
Content-Disposition: attachment; filename=\"test.log\"\n\n"
# Then, read in the data you wish to attach.
if [catch {open "flash:test.log"} result] {
    error $result $errorInfo
set fd $result
# Encode that data using the built-in base64 library.
set email_b64 [::base64::encode [read $fd]]
close $fd
# Construct the final message with the headers, body, and MIME parts.
set email_body_mime "\n--EEM_email_boundary--"
set email_body [format "%s%s%s" $email_body_pre $email_b64 $email_body_mime]
# Send the email.
if [catch {smtp_send_email $email_body} result] {
ideocisco
What if you need to send 2 attachments and add text in the body of the email?
Stéphane
Joe Clarke
You just need to add more boundaries (i.e. more EEM_email_boundary sections).  The text body will come between the first two in $email_body_pre.
ideocisco
Thanks for your fast response.
I am new to this, so please forgive my lack of knowledge.
Is this what you mean :
MIME-Version: 1.0
This is a test to appear in the body of the message
Content-Disposition: attachment; filename=\"test2.log\"\n\n"
Stéphane
Joe Clarke
Yep.
ideocisco
Thanks this works perfectly nice.
Another question.
What if I wanted to attach text already in a variable. Is this possible?
Ex :
set email_attachment_1 "This is a test"
Content-Disposition: attachment; filename=\"Message.txt\"\n\n"
set email_b64 [::base64::encode [$email_attachment_1]]
Stéphane
Joe Clarke
Yes, that will work as well.
ideocisco
I get the following error :
Router#event manager run Test.tcl
invalid command name "
 Pool Tag: 21
 MAC Address                : AAAA.AAAA.AAAA
 No. of attempts to register: 0
 Unregister time            :
 Last register request time :
 Reason for state unregister:
         No registration request since last reboot/unregister
 Pool Tag: 22
 MAC Address                : BBBB.BBBB.BBBB
 Unregister time            :
Router#"
    while executing
"$email_attachment_1"
    invoked from within
"if {$ata_down} {
  append email_pre "$msg"
  app..."
    (file "tmpsys:/eem_policy/Test.tcl" line 179)
Tcl policy execute failed: invalid command name "
 Pool Tag: 21
 Unregister time            :
 Pool Tag: 22
 Unregister time            :
$email_attachment_1 contains the following :
 Pool Tag: 21
 Unregister time            :
 Pool Tag: 22
 Unregister time            :
Joe Clarke
You can't put brackets around your variable.  It should be:
set email_b64 [::base64::encode $email_attachment_1]
ideocisco
Thank you Joseph.
You are truly the best contributer I have the please to chat with.
This is working like a charm.
Stéphane
ideocisco
When I try to have 2 attachments, I do not get the results expected. The first attachment is empty and the 2nd attachment contains the data of the 2 files.
Here is my code :
set email_pre "Mailservername: $_email_server
To: $_email_to
Cc:
Subject: Test 2 attachment
MIME-Version: 1.0
This is a test email with 2 attachments"
append email_pre "\n--EEM_email_boundary
set fd $result
close $fd
if [catch {open "flash:test2.log"} result] {
set fd $result
set email_b64_2 [::base64::encode [read $fd]]
close $fd
set email_body [format "%s%s%s" $email_pre $email_b64 $email_b64_2 $email_body_mime]
Joe Clarke
You need to have the boundaries between your attachments.  Appending another boundary to email_pre doesn't do you any good.  Best to gave email_pre be your initial headers and email body.  Then each attachment will start its boundary and MIME info.
ideocisco
Don't I have boudaries between my attachments :
Joe Clarke
No, because $email_pre is only included at the front of you email.  You construct the email as:
email_pre
email_b64
email_b64_2
email_body_mime
You need a boundary and MIME header before email_b64 and before email_b64_2.
ideocisco
So something like :
set email_pre2 "MIME-Version: 1.0
set email_body [format "%s%s%s%s%s%s" $email_pre $email_b64 $email_body_mime $email_pre2 $email_b64_2 $email_body_mime]
ideocisco
I am getting there.
The above code sends me three attachments.
The 2 log files and the Body message both in the message and as an attachment.
