TCC_2
Level 10
Level 10
Resolution
To change from a switch prompt to a module prompt, such as a router module, the session mod command or the switch console mod (on Catalyst 6000 series switches) command may be issued.
When issuing the session mod number command, first issue the show module command to determine the module number for which you need access. In the following example, the Multilayer Switch Feature Card (MSFC) is module 15. The session 15 command connects the session to the MSFC. In order to go back to the Supervisor prompt after issuing the session command, the exit or logout command must be issued at the MSFC's prompt.
  Console> (enable)show module
  Mod Slot Ports Module-Type               Model               Sub Status
  1   1    2     1000BaseX Supervisor      WS-X6K-SUP1A-2GE    yes ok
  15  1    1     Multilayer Switch Feature WS-F6K-MSFC         no  ok
  2   2    2     1000BaseX Supervisor      WS-X6K-SUP1A-2GE    yes standby
  4   4    48    10/100BaseTX Ethernet     WS-X6248-RJ-45      no  ok
  Mod Module-Name          Serial-Num
  1                        SAD04290J4L
  15                       SAD04281BDB
  2                        SAD04010FB3
  4                        SAD050504PM
  Console> (enable) session 15
  Trying Router-15...
  Connected to Router-15.
  Escape character is '^]'.
  Router>en
  Router#exit
  Console> (enable)
The switch console mod command is only supported on the Catalyst 6000 series switches. In order to switch back to the Supervisor prompt in this mode, hold down the Ctrl key and press c three times. The exit or logout command does not work when the switch console command has been used to gain access to another module. If only one MSFC is installed, the module number does not need to be specified.
Console> (enable) switch console
Trying Router-15...
Type ^C^C^C to switch back...
Router>en
Router#
Router#
Router#^C
Console> (enable)
