VLA_WeyBridge_2
I have a 1841 that I am trying to get the ADSL link to come up on.
My ATM interface is showing as Down Down.
Running a debug atm events shows
open failed: Protocol error recived -- retrying?
I have updated the ios to 12.4(24)T1 and before this, the card was working.
Could this be a firmware mismatch error, and if so how can i go about seeing what firmware version the ADSL-WIC card is running and upgrading it if nessery?
Cheers
Aaron
VLA_WeyBridge_2
some more of the error message
*Oct 19 15:02:43.159: DSL(ATM0/0/0): Using preferred open mode
*Oct 19 15:02:43.159: DSL(ATM0/0/0): Using ITU sync first for 5 secs, then ANSI/ITU sync alternatively for 2 secs
*Oct 19 15:02:43.159: DSL(ATM0/0/0): Using subfunction 0x0
*Oct 19 15:02:43.159: LOCAL:Max noise margin for power cutoff 31
*Oct 19 15:02:43.159: DSL(ATM0/0/0): GPCI[0] 0x5
*Oct 19 15:02:43.159: DSL(ATM0/0/0): GPCI[1] 0x9
*Oct 19 15:02:43.159: DSL(ATM0/0/0): GPCI[2] 0x1
*Oct 19 15:02:43.159: DSL(ATM0/0/0): GPCI[3] 0x0
*Oct 19 15:02:43.159: DSL(ATM0/0/0): Sent extended command 0x3
*Oct 19 15:02:45.659: DSL(ATM0/0/0): 1: Modem state = 0x9
*Oct 19 15:02:48.159: DSL(ATM0/0/0): 2: Modem state = 0x9
*Oct 19 15:02:50.659: DSL(ATM0/0/0): 3: Modem state = 0x10
*Oct 19 15:02:53.159: DSL(ATM0/0/0): 4: Modem state = 0x10
*Oct 19 15:02:53.623: DSL(ATM0/0/0): Received response: 0x22
*Oct 19 15:02:53.623: DSL(ATM0/0/0): Open failed: Handshake or init message invalid or had bad CRC -- retrying
*Oct 19 15:02:53.623: DSL(ATM0/0/0): sleep 5 seconds
*Oct 19 15:02:58.623: DSL(ATM0/0/0): Send ADSL_OPEN command.
*Oct 19 15:02:58.623: dslsar enable ATM0/0/0
*Oct 19 15:02:58.623: DSL(ATM0/0/0): Using preferred open mode
*Oct 19 15:02:58.623: DSL(ATM0/0/0): Using ITU sync first for 5 secs, then ANSI/ITU sync alternatively for 2 secs
*Oct 19 15:02:58.623: DSL(ATM0/0/0): Using subfunction 0x0
*Oct 19 15:02:58.623: LOCAL:Max noise margin for power cutoff 31
*Oct 19 15:02:58.623: DSL(ATM0/0/0): GPCI[0] 0x5
*Oct 19 15:02:58.623: DSL(ATM0/0/0): GPCI[1] 0x9
*Oct 19 15:02:58.623: DSL(ATM0/0/0): GPCI[2] 0x1
*Oct 19 15:02:58.623: DSL(ATM0/0/0): GPCI[3] 0x0
*Oct 19 15:02:58.623: DSL(ATM0/0/0): Sent extended command 0x3
*Oct 19 15:03:01.123: DSL(ATM0/0/0): 1: Modem state = 0x9
*Oct 19 15:03:03.623: DSL(ATM0/0/0): 2: Modem state = 0x9
*Oct 19 15:03:06.123: DSL(ATM0/0/0): 3: Modem state = 0x10
*Oct 19 15:03:06.623: DSL(ATM0/0/0): Received response: 0x22
*Oct 19 15:03:06.623: DSL(ATM0/0/0): Open failed: Protocol error received -- retrying
*Oct 19 15:03:06.623: DSL(ATM0/0/0): sleep 5 seconds
*Oct 19 15:03:11.623: DSL(ATM0/0/0): Send ADSL_OPEN command.
*Oct 19 15:03:11.623: dslsar enable ATM0/0/0
dpetrucci1029
I would go into Software Advisor and there is a link where you can find software that is compatible with your hardware. From there you should see the model ADSL card you have and it will tell you what version of code you need for that hardware feature.
VLA_WeyBridge_2
Hi I have looked in to this further. It was very poor line quility and the protocol would not come up. Thank you for the help.
aaron
