kishorecisco
Hi, i'm working on Eigrp. I issued the command ip bandwidth-percent eigrp but i dont know how to check is this command working fine.
I Tried traceroute before issuing this command it showed that the network is load balanced. But still after issuing ip bandwidth-percent  command i'm getting the same result. Tell me how to  check whether this command is functioning properly.
