leandro11603
Community Member
I am new to this forum and do need your help, please.
I'm trying to configure a network with cisco devices:
Cisco 2960 12 8 ports
Cisco 877 4 Switch ports
2 7911 IP Phones.
In switch i have created the following VLANS:
VLAN SRV (Switch ports 1,2)  ---  192.168.1.0/27  (Gateway 192.168.1.1)
VLAN VOICE (Switch ports 3,4) ---  192.168.1.32/27 (Gateway 192.168.1.33)
VLAN USERS1 (Switch ports 5,6) ---  192.168.1.64/27 (Gateway 192.168.1.65)
VLAN USERS2 Connect to IP Phone PC port  ---  192.168.1.96/27 (Gateway 192.168.1.97)
VLAN MGMT (Switch port 7) - 192.168.1.128/27 (Gateway 192.168.1.1)
Switch port 8 (trunk all created vlans) connected to Router port 2
In router:
Router Port 1 connected to ISP Router port 1.
Please, can you help me with the router side configuration to allow all switch vlan to access internet and be able to have voice setup.
This router does not have L3 ports on wich that i can create sub-interfaces.
I know that i can create virtual interface on these ports, but i don´t exacly which should be the rigth configuration.
Million thanks in advance.
Kind regards,
Leandro Vieira
leandro11603
Community Member
Please, i do need you help. Can anybady help.
Thanks in advance,
Kind regards,
Leandro Vieira
