ashirkar
Level 7
Level 7
Introduction:
In last document we have discussed the concept of multicast RPF and understand what happens when there is RPF failure. In this document we will discuss on how you can configure RPF statically using “static multicast route“
Multicast static route (mroute) configures using the "ip mroute" command in global configuration mode; similar like normal static route.Here is command syntax:
ip mroute source-address mask [protocol as-number] {rpf-address | type number} [distance]
Configuration Example:
Whenever R3 performs the RPF check, it will examine the Source address (1.1.1.2) of incoming packet then it will check the routing table for that source address. In our case R3 learnt route to 1.1.1.0/24 from interface fa0/0 hence for multicast source address 1.1.1.2 interface fa0/0 is RPF interface. So whenever R3 will receive multicast packets from source 1.1.1.2 on interface fa0/0 it will accept those and forward to downstream host but it will drop the packets comes on s0/0 from R2.
Now In our scenario, we want to utilize R3's both the links; fast Ethernet0/0(unicast) and Serial0/0(multicast).
Topology Diagram:
Initial Configuration:
R1R2R3R4
hostname R1
ip cef
ip multicast-routing
interface FastEthernet0/0
ip address 10.1.1.1 255.255.255.252
ip pim dense-mode
speed 100
full-duplex
interface FastEthernet0/1
ip address 10.1.1.5 255.255.255.252
ip pim dense-mode
speed 100
full-duplex
interface FastEthernet1/0
ip address 1.1.1.1 255.255.255.0
ip pim dense-mode
duplex auto
speed auto
router eigrp 1
network 1.1.1.1 0.0.0.0
network 10.1.1.0 0.0.0.255
no auto-summary
hostname R2
ip address 10.1.1.2 255.255.255.252
ip pim dense-mode
speed 100
full-duplex
interface Serial0/0
ip address 10.1.1.9 255.255.255.252
ip pim dense-mode
clock rate 2000000
router eigrp 1
no auto-summary
hostname R3
ip address 10.1.1.6 255.255.255.252
ip pim dense-mode
no ip route-cache cef
no ip route-cache
no ip mroute-cache
speed 100
full-duplex
interface Serial0/0
ip address 10.1.1.10 255.255.255.252
ip pim dense-mode
no ip route-cache
no ip mroute-cache
clock rate 2000000
ip address 3.3.3.3 255.255.255.0
ip pim dense-mode
ip igmp join-group 239.1.1.1
speed 100
full-duplex
router eigrp 1
network 3.3.3.3 0.0.0.0
no auto-summary
hostname R4
interface Loopback0
ip address 4.4.4.4 255.255.255.0
ip address 3.3.3.2 255.255.255.0
ip pim dense-mode
speed 100
full-duplex
ip pim dense-mode
duplex auto
speed auto
router eigrp 1
network 192.168.1.0
network 0.0.0.0
no auto-summary
Let’s trace route to 192.168.1.1 to check unicast path from R1:
R1#traceroute 192.168.1.1 so fa1/0
Tracing the route to 192.168.1.1
  1 10.1.1.6 40 msec 52 msec 44 msec
  2 3.3.3.2 56 msec 68 msec *
Also do Mtrace route to 192.168.1.1 to check multicast path from R1:
R1#mtrace 1.1.1.2 192.168.1.1 239.1.1.1
Mtrace from 1.1.1.2 to 192.168.1.1 via group 239.1.1.1
From source (?) to destination (?)
Querying full reverse path...
0  192.168.1.1
-1  3.3.3.2 PIM  [1.1.1.0/24]
-2  3.3.3.3 PIM  [1.1.1.0/24]
-3  10.1.1.5 PIM  [1.1.1.0/24]
-4  1.1.1.2
From the both traces its clear that unicast as well multicast traffic path is through R3’s interface fa0/0.
To change traffic path to s0/0 we need to change RPF interface for 1.1.1.0/24 from interface Fa0/0 to s0/0, which can be done by configuring static multicast route pointing towards s0/0 as shown below:
R3#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
R3(config)#ip mroute 0.0.0.0 0.0.0.0 s0/0
R3(config)#end
R3#
Now check RPF interface for multicast server IP address 1.1.1.2
R3#sh ip rpf
R3#sh ip rpf 1.1.1.2
RPF information for ? (1.1.1.2)
  RPF interface: Serial0/0
  RPF neighbor: ? (10.1.1.9)
  RPF route/mask: 1.1.1.0/24
  RPF type: static
  RPF recursion count: 0
  Doing distance-preferred lookups across tables
Base Initial configuration:
Verification:
To verify multicast path, sending ICMP packets S1 to group address 239.1.1.1 and capturing mpacket debug on R3.
R3#conf t
R3(config)#logging console 5
R3(config)#logging buffer 7
R3(config)#logging buffer 64000
R3(config)#no service timestamp
R3(config)#end
R3#debug ip mpacket
IP multicast packets debugging is on
C:\>ping 239.1.1.1
Pinging 239.1.1.1 with 32 bytes of data:
Reply from 10.1.1.10: bytes=32 time=81ms TTL=254
Reply from 10.1.1.10: bytes=32 time=61ms TTL=254
Reply from 10.1.1.10: bytes=32 time=32ms TTL=254
Reply from 10.1.1.10: bytes=32 time=60ms TTL=254
Ping statistics for 239.1.1.1:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 32ms, Maximum = 81ms, Average = 58ms
R3#sh logging  | beg Log
    Logging Exception size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
No active filter modules.
ESM: 0 messages dropped
    Trap logging: level informational, 26 message lines logged
Log Buffer (64000 bytes):
IP(0): s=1.1.1.2 (FastEthernet0/0) d=239.1.1.1 id=298, ttl=62, prot=1, len=74(60), not RPF interface
IP(0): s=1.1.1.2 (Serial0/0) d=239.1.1.1 (FastEthernet0/1) id=298, ttl=61, prot=1, len=60(60), mforward
IP(0): s=1.1.1.2 (Serial0/0) d=239.1.1.1 (FastEthernet0/0) id=298, ttl=61, prot=1, len=60(60), mforward
IP(0): s=1.1.1.2 (FastEthernet0/0) d=239.1.1.1 id=300, ttl=62, prot=1, len=74(60), not RPF interface
IP(0): s=1.1.1.2 (Serial0/0) d=239.1.1.1 (FastEthernet0/1) id=300, ttl=61, prot=1, len=60(60), mforward
IP(0): s=1.1.1.2 (Serial0/0) d=239.1.1.1 (FastEthernet0/0) id=300, ttl=61, prot=1, len=60(60), mforward
IP(0): s=1.1.1.2 (Serial0/0) d=239.1.1.1 (FastEthernet0/1) id=302, ttl=61, prot=1, len=60(60), mforward
R3#sh ip mroute 1.1.1.2 239.1.1.1 | beg 1.1.1.2
(1.1.1.2, 239.1.1.1), 00:02:00/00:01:02, flags: LT
  Incoming interface: Serial0/0, RPF nbr 10.1.1.9, Mroute
  Outgoing interface list:
    FastEthernet0/1, Forward/Dense, 00:02:00/00:00:00
    FastEthernet0/0, Prune/Dense, 00:01:59/00:01:00, A
2) You can also do mtrace to verify path from R1 as shown below:
0  192.168.1.1
-2  3.3.3.3 PIM/Static  [default]
-3  10.1.1.9 PIM  [1.1.1.0/24]
-4  10.1.1.1 PIM  [1.1.1.0/24]
-5  1.1.1.2
Also See:
Understanding Basics of Multicast RPF (Reverse Path Forwarding
sunishgandhi
Community Member
simple explanation made understanding very easy...
ashirkar
Level 7
Level 7
Hello sunish,
Thanks for your Positive feedback.
Ashish Shirkar
(Technical Community Manager-Network Infrastructure)
