Kt43387
import netmiko
from netmiko import ConnectHandler
device = ConnectHandler(device_type="cisco_ios", ip="DEVICE IP", username="USERNAME", password="PASSWORD")
output1 = device.send_command("show running-config")
save_file = open("Switch_running.txt","w")
save_file.write(output1)
save_file.close()
device.disconnect()
#python#automation#
sagrai
Working command is below:
iou1 = {
'device_type': 'cisco_ios',
'ip': '172.16.221.106',
'username': 'admin',
'password': 'cisco',
device = ConnectHandler(**iou1)
save_file.close()
device.disconnect()
kkowalczyk
An option using the CiscoAutomationFramework package would be below, might be a little more straight forward as the package handles things like OS detction and has integrated functions to get data like the running config so you dont have to worry about setting things like the terminal length to get all of the output.
https://github.com/superadm1n/CiscoAutomationFramework/blob/master/ExampleScripts/config_backup.py
The link above is an example config backup script included with the package, below would be something that functionally does the same as your example
from CiscoAutomationFramework import connect_ssh
with connect_ssh('IP', 'USERNAME', 'PASSWORD') as ssh:
device_config = ssh.running_config
with open('path/to/my/file.txt', 'w') as f:
f.write(device_config)
Martin L
thanks for sharing !
