TCC_2
Level 10
Level 10
Core Issue
Before exchanging routing information, routers running Open Shortest Path First (OSPF) form neighbor relationship with other OSPF routers on the same segment by exchanging hello packets. The hello packets contain various parameters. Some of them should match between neighboring routers. These include:
  • Hello and Dead intervals
  • Area ID
  • Authentication type and password
  • Stub Area flag
  • Subnet ID and Subnet mask
If any of these parameters do not match, the router from which the hello packets are received is not considered as a neighbor. Adjacency establishment does not proceed further, resulting in routing failures.
The mismatch occurs primarily due to configuration errors related to any of these parameters. The hello and dead interval mismatches are more common when OSPF operates over Non-Broadcast Multi-Access (NBMA) networks such as Frame Relay and ATM hub and spoke environments, where physical interfaces are used on one end and point-to-point sub-interfaces are used on the other end. This results in different OSPF network types on either ends, using different hello and dead interval timers when they are left with the default configurations.
Resolution
Issue the show ip ospf neighbor command from the privileged EXEC mode to identify the adjacency state with the neighbor. When a mismatch exists, the output of this command is empty if the neighbors are trying to be discovered automatically. If the neighbors are statically configured, the neighbor is displayed in DOWN state.
If neighbor relationships are not being formed over an interface, issue the show ip ospf interface command to view the hello and dead intervals, IP address, subnet mask and Area ID parameters. You can use the show ip ospf command to identify if any stub areas are configured.
You can also use the debug ip ospf hello and debug ip ospf adj commands from the privileged EXEC mode to identify which parameter has a mismatch.
To modify the Hello and Dead timers, use the ip ospf hello-interval seconds and ip ospf dead-interval seconds commands from the interface configuration mode.
To modify area to which the interface belongs, use the router ospf process-id command in the global configuration mode, followed by the no network ip-address wildcard-mask area area-id command under the router configuration mode to remove the interface from the specific area, and then issue the network ip-address wildcard-mask area area-id command to include the interface under the correct area.
To modify the authentication type, issue the area area-id authentication [message-digest] command under the router configuration mode or the ip ospf authentication [message-digest | null] command under the interface configuration mode. To configure the correct passwords, use the ip ospf authentication-key password or ip ospf message-digest-key key-id md5 key command under the interface configuration mode.
To set the stub area flag, configure the area as stub or Not-So-Stubby-Area (NSSA), by issuing the area area-id stub or area area-id nssa commands from the router configuration mode.
To change the IP address and subnet mask, issue the ip address ip-address mask command under the interface configuration mode.
For related information, refer to OSPF Neighbor Problems Explained.
show ip ospf neighbors
Init
No output received
