sdheer
Introduction:
In this document you will learn about some basic terms like OUTPUT DROPS, INPUT QUEUE DROPS, HOLD-QUEUE IN and HOLD-QUEUE OUT.
OUTPUT DROPS:
Every port has some kind of receive and transmit buffering.  These buffers are used to store frames, as forwarding decisions are made within the switch, or as packets are en-queued for transmission on a port at a rate greater than the physical medium can support.
In tx direction you would see 'Total output drops' counter moving when hw or sw switched traffic is dropped due to lack of port asic tx buffers.
For Layer 2 interfaces, "Total output drop" is caused by lack of port asic tx buffer, which impacts both hw and cpu switched traffic, most of the time due to oversubscription, or very high traffic rate or due to busty traffic .
Output drops on interface typically indicate an oversubscription problem, and will increment when the rate of traffic coming from the fabric exceeds the ability to put the data on the wire, and tx buffering is depleted.
INPUT QUEUE DROPS:
With Layer 2 interface, the input hold-queue drop is not just for CPU traffic but other input drop (for example overrun) will also be counted to input hold-queue drop.
Here is a sample output:
router1#show interfaces ethernet 0/0
Input queue: 30/75/187/0 (size/max/drops/flushes); Total output drops: 0
Output queue :0/40 (size/max)...
For Layer 2 interface, although the drop counter of "input-queue drop" counts both hw switched traffic and traffic punted to CPU, the input-hold queue itself which can be tuned by "hold-queue xx in" is actually used to buffer traffic punted to CPU only. So if the "input-queue drop" is actually caused by hw switched traffic lack of port asic rx buffer, then increase "hold-queue xx in" will not help
Input Queue drops on Layer 3 vlan interfaces are caused by excessive traffic destined to the CPU.  The input queue on a L3 interface by default can hold 75 packets.
As packets are destined for the CPU they are stored in this input queue until the CPU can service this queue.  If the rate at which the packets are hitting this queue is greater than the frequency in which it is serviced, we drop packets.  Sometimes this is expected based on your traffic patterns, sometimes it's not
Input queue drop counter counts hw switched traffic which was dropped due to lack of port asic rx buffer. It would also count traffic destine to sp and dropped by sp (not very likely to happen)
For 6500 platforms:
The hold queue parameter is a way to reserve buffer for the RP buffer space. This command will reserve more space for non-priority data (e.g.ARP) that hit the RP. It will not affect data plane traffic like VOIP.
HOLD-QUEUE IN:
input hold-queue at Layer 3 port (by  default 75)
input hold-queue at Layer 2 port (by default 2000)
Input hold-queue at both Layer2 and Layer3 interface are using SP and RP I/O memory on supervisor.
HOLD-QUEUE OUT:
output hold-queue at Layer 2 port (by default 40)
output hold-queue at Layer 3 port (by default 40)
Output hold-queue at both Layer2 and Layer3 interface are using SP and RP I/O memory on supervisor.
Output hold-queue is software queue allocated by system memory .The output hold-queue, which can be tuned by "hold-queue x out" is actually only used for traffic processed by CPU
Hope this very basic document is useful
Cheers!!
Related Information:
Troubleshooting Input Queue Drops and Output Queue Drops
Understanding Queue Limits and Output Drops on Cisco IOS Software Platforms
jordihernandezvidal
Community Member
Many Thank Swati!
regards,
Jordi
shewang
Hi Swati,
Many thanks for this post.
Could you advise if the counter in input queue size is current or history counter?
As I observed, the number 3006 as in "Input queue: 3006/2000/63932087/0 (size/max/drops/flushes)" remains same after I leave the port shut for a day. If it is current number of packets waiting to be processed, post processing the number should be cleared as those packets are no longer waiting; If it is a history counter and only increment, how come the drops only starts after size reaches max 2000?
Best regards,
Shelly
Rich R
@shewang that number should normally be zero if the interface is shut - it's the current queue length.
If it stays at 3006 that implies a queue wedge condition.
These are invariably caused by IOS bugs and usually classified as DOS security vulnerabilities.
For example: https://sec.cloudapps.cisco.com/security/center/content/CiscoSecurityAdvisory/cisco-sa-quewedge-69BsHUBW
What platform is this on?
What version of IOS?
What interface?
shewang
@Rich R Thanks a lot for your reply.
Platform: C9200L
IOS XE software: 17.03.06
Interface: 10Gig  Full-duplex, 10Gb/s, link type is auto, media type is SFP-10GBase-LR
The number could drop a little between 1 to 10 sometimes but it never go back to 0.
I've left the port up with low rate of traffic, now I check it is 3005 and it remained this way for 3 days.
Input queue: 3005/2000/63932087/0 (size/max/drops/flushes); Total output drops: 0
I will upgrade the switch to current Cisco recommended to check how it behaves.
Thank you
Shelly
Rich R
17.3 is now rather old and quite advanced towards End of Life - already past End of SW Maintenance and End of Vulnerability/Security Support!
https://www.cisco.com/c/en/us/products/collateral/ios-nx-os-software/ios-xe-17/ios-xe-17-3-x-eol.html
So yes - any testing should be done on a current recommended release:
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9300-series-switches/214814-recommended-releases-for-catalyst-9200-9.html
Martin L
thanks for this info!
shewang
@Rich R
Sorry, forgot to update here, upgrading to the current recommended release fixed the issue.
Thank you so much!
Rich R
Glad to hear it @shewang - that's always a good starting for testing that kind of issue.
