04-25-2013 12:54 AM - edited 03-01-2019 04:54 PM
Hello, this document will briefly discuss my implementation on how to configure OTV on ASR 1000 series routers. I know there is plenty of documentation out there, and many people have questions about which interfaces are useable etc...
There are some prerequisites that you should be aware of.
GOAL: to extend vlan 724 across datacenters and be able to see a mac address from vlan 724 originating from the other DC and seeing it in the other DC.
In my scenario I have ASR 1002's but within the same network I have ASR1001's working too. The layer 2/3 devices consist of 6500's and a 3750 - will follow a multi-homing setup.
Here is a diagram of the physical network.
Multicast has already been setup, with one single RP.
I'll be using one link on the INSIDE for both routing and trunking. So from each 6500 and 3750 is a trunk carrying my OTV vlan that I want to stretch across datacenters and also an SVI for my routing in OSPF area 0.
All my layer 3 is in place and have full connectivity everywhere. Each link is a point-to-point link.
ASR's need a dedicated vlan for the AED election to take place on the INSIDE.
Note: A lot of engineers out there have a problem in getting OTV working because there is something wrong with the election. This would look a little like this:
ASR-TEST#show otv
Overlay Interface Overlay1
VPN name : overlay1
VPN ID : 1
State : UP
AED Capable : No, overlay DIS not elected
IPv4 control group : 239.1.1.1
Mcast data group range(s): 232.0.0.0/8
Join interface(s) : GigabitEthernet0/0/0
Join IPv4 address : 10.99.99.2
Tunnel interface(s) : Tunnel0
Encapsulation format : GRE/IPv4
Site Bridge-Domain : 401
Capability : Multicast-reachable
Is Adjacency Server : No
Adj Server Configured : No
Prim/Sec Adj Svr(s) : None
Also another thing that caught me out is having the election vlan on the overlay interface - it should not be on the overlay interface! only the INSIDE interface.
So in our case we will use VLAN 8 and call this the 'OTV' vlan for the elections. The election will take place on this segment and the 6500 and the 3750 will provide that transport mechanism for this.
Also we mentioned that we want to extend vlan 724 across our datacenters, so we will configure this too
Not to mention we will also configure gi9/14 on both sides and an SVI for routing purposes. The 6500's have a trunk between them which is allowing all vlans across it.
DC1-6509-1 | DC1-6509-2 |
conf t ! vlan 8 name OTV ! vlan 724 name Server ! interface gi9/14 switchport switchport trunk encapsulation dot1q switchport mode trunk switchport trunk allowed vlan 8,724,1511 ! interface vlan 1511 description ## ROUTED TO ASR01 ## ip address 192.168.11.2 255.255.255.252 ip ospf 1 area 0 ip ospf network point-to-point | conf t ! vlan 8 name OTV ! vlan 724 name Server ! interface gi9/14 switchport switchport trunk encapsulation dot1q switchport mode trunk switchport trunk allowed vlan 8,724,1512 ! interface vlan 1512 description ## ROUTED TO ASR02 ## ip address 192.168.12.2 255.255.255.252 ip ospf 1 area 0 ip ospf network point-to-point |
Now we have the 6509's set up lets go to the ASR's (1002) where things get more interesting!
Here we will configure the INSIDE interfaces which will be towards the trunk, also a sub-interface for our routing with vlan 15XX. The join interface which will be a LOOPBACK interface! and lastly the Overlay interface.
Note that the loopback interface is also advertised by OSPF.
DC-ASR1002-01 | DC-ASR1002-02 |
ip multicast-routing distributed ! otv site bridge-domain 8 ! otv site-identifier 0000.0000.0001 ! interface Loopback10 description ## OTV JOIN INTERFACE ## ip address 192.168.230.254 255.255.255.255 ip mtu 1600 ip pim passive ip igmp version 3 ! interface Overlay1 no ip address otv control-group 239.1.1.1 otv data-group 232.1.1.0/28 otv join-interface Loopback10 !service instance 724 ethernet encapsulation dot1q 724 bridge-domain 724 ! interface GigabitEthernet0/0/1 description ## OTV INSIDE to 6509-1 Gi9/14 ## no ip address negotiation auto cdp enable service instance 8 ethernet encapsulation dot1q 8 bridge-domain 8 !service instance 724 ethernet encapsulation dot1q 724 bridge-domain 724 ! interface GigabitEthernet0/0/1.1511 description ## ROUTED TO ASR01 ## ip address 192.168.11.1 255.255.255.252 ip pim sparse-mode ip ospf 1 area 0 ip ospf network point-to-point | ip multicast-routing distributed ! otv site bridge-domain 8 ! otv site-identifier 0000.0000.0001 ! interface Loopback10 description ## OTV JOIN INTERFACE ## ip address 192.168.230.253 255.255.255.255 ip mtu 1600 ip pim passive ip igmp version 3 ! interface Overlay1 no ip address otv control-group 239.1.1.1 otv data-group 232.1.1.0/28 otv join-interface Loopback10 ! service instance 724 ethernet encapsulation dot1q 724 bridge-domain 724 ! interface GigabitEthernet0/0/1 description ## OTV INSIDE to 6509-2 Gi9/14 ## no ip address negotiation auto cdp enable service instance 8 ethernet encapsulation dot1q 8 bridge-domain 8 ! service instance 724 ethernet encapsulation dot1q 724 bridge-domain 724 ! interface GigabitEthernet0/0/1.1512 description ## ROUTED TO ASR01 ## ip address 192.168.12.1 255.255.255.252 ip pim sparse-mode ip ospf 1 area 0 ip ospf network point-to-point |
I haven't shown the WAN interfaces - its pretty standard point-to-point connections.
Now going to do some show commands:
DC1-ASR1002-02#show otv site
Site Adjacency Information (Site Bridge-Domain: 8)
Overlay1 Site-Local Adjacencies (Count: 2)
Hostname System ID Last Change Ordinal AED Enabled Status
DC1-ASR1002-01 5057.A898.F700 7w0d 0 site overlay
*DC1-ASR1002-02 5057.A899.3300 7w0d 1 site overlay
DC1-ASR1002-02#show otv overlay 1
VPN name : None
VPN ID : 1
State : UP
AED Capable : Yes
Mcast data group range(s): 232.1.1.0/28
Join interface(s) : Loopback10
Join IPv4 address : 192.168.230.253
Tunnel interface(s) : Tunnel2
Site Bridge-Domain : 8
DC-ASR1002-02#show otv vlan
Key: SI - Service Instance
Overlay 1 VLAN Configuration Information
Inst VLAN Bridge-Domain Auth Site Interface(s)
0 724 724 no Gi0/0/1:SI724
Since DC1-ASR1002-02 is not the primary AED for this instance we'll have to take a look at 01 to see if it see's any mac addresses in this vlan on the INSIDE interface. I have plugged in several devices in to the 6509 on vlan 724:
DC1-ASR1002-01#show otv route vlan 724
Codes: BD - Bridge-Domain, AD - Admin-Distance,
SI - Service Instance, * - Backup Route
OTV Unicast MAC Routing Table for Overlay1
Inst VLAN BD MAC Address AD Owner Next Hops(s)
0 724 724 000c.29f5.8b08 40 BD Eng Gi0/0/1:SI724
0 724 724 001f.2959.e17f 40 BD Eng Gi0/0/1:SI724
Good, so there are, our aim is to be able to see these on the switch on the other side!
Lets go over to DC2 - the ASR's:
DC2-ASR1002-01 | DC2-ASR1002-02 |
ip multicast-routing distributed ! otv site bridge-domain 8 ! otv site-identifier 0000.0000.0003 interface Loopback10 ip address 192.168.230.251 255.255.255.255 ip mtu 1600 ip pim passive ip igmp version 3 ! interface Overlay1 no ip address otv control-group 239.1.1.1 otv data-group 232.1.1.0/28 otv join-interface Loopback10 service instance 724 ethernet encapsulation dot1q 724 bridge-domain 724 ! interface GigabitEthernet0/0/2 description ## Trunk OTV & ROUTE ## Gi0/1 ## no ip address negotiation auto cdp enable service instance 8 ethernet encapsulation dot1q 8 bridge-domain 8 !service instance 724 ethernet encapsulation dot1q 724 bridge-domain 724 ! interface GigabitEthernet0/0/2.1521 description ## Core Routing DR-3750-1 P2P ## VLAN1521 ## encapsulation dot1Q 1521 ip address 192.168.21.2 255.255.255.252 ip pim sparse-mode ip ospf network point-to-point ip ospf 1 area 0 | ip multicast-routing distributed ! otv site bridge-domain 8 ! otv site-identifier 0000.0000.0003 interface Loopback10 ip address 192.168.230.250 255.255.255.255 ip mtu 1600 ip pim passive ip igmp version 3 ! interface Overlay1 no ip address otv control-group 239.1.1.1 otv data-group 232.1.1.0/28 otv join-interface Loopback10 service instance 724 ethernet encapsulation dot1q 724 bridge-domain 724 ! interface GigabitEthernet0/0/2 description ## Trunk - OTV & ROUTE ## Gi0/1 ## no ip address negotiation auto cdp enable service instance 8 ethernet encapsulation dot1q 8 bridge-domain 8 ! service instance 724 ethernet encapsulation dot1q 724 bridge-domain 724 !interface GigabitEthernet0/0/2.1522 description ## Core Routing DR-3750-1 P2P ## VLAN1521 ## encapsulation dot1Q 1522 ip address 192.168.22.2 255.255.255.252 ip pim sparse-mode ip ospf network point-to-point ip ospf 1 area 0 |
Now we need to get that 3750 up and running so we'd do this:
conf t
vlan 8
name OTV
vlan 724
name server
interface GigabitEthernet1/1/1
description ## Trunk to DC2-ASR1002-01 ## Gi0/0/2 ##
switchport trunk allowed vlan 8,724,1521
interface GigabitEthernet2/1/1
description ## Trunk to DC2-ASR1002-02 ## Gi0/0/2 ##
switchport trunk allowed vlan 8,724,1522
interface Vlan1521
description ## Core Routing DC2-ASR002-01 P2P ## VLAN 1521 ##
ip address 192.168.21.1 255.255.255.252
ip ospf 1 area 0
interface Vlan1522
description ## Core Routing DC2-ASR002-02 P2P ## VLAN 1522 ##
ip address 192.168.22.1 255.255.255.252
ip ospf 1 area 0
Now we have this done, OTV should be working fine, so lets check it out.
DC1-ASR1002-01#show otv adjacency
Overlay 1 Adjacency Database
Hostname System-ID Dest Addr Up Time State
DC1-ASR1002-02 5057.a899.3300 192.168.230.253 28w3d UP
DC2-ASR1002-01 5057.a898.fa00 192.168.230.251 1w1d UP
DC2-ASR1002-02 5057.a898.fa03 192.168.230.250 1w1d UP ]
Now we are able to see all the ASR's that are adjacent, lets look if the mac addresses are in the IS-IS routing table that OTV uses.
Remember we saw these?
So if we do a 'show otv route | inc 001f.2959.e17f on DC2-ASR1002-01 we should see that it is learnt via ISIS:
DR-ASR1002-01#show otv route | inc 001f.2959.e17f
0 724 724 001f.2959.e17f 50 ISIS DC1-ASR1002-01
Finally, almost there - couple more checks, we know that the ASR knows how to route via OTV to that mac address, we just need to check if the 3750 on the other side knows about it too!
So we'll hop over to the 3750 and do a 'show mac address-table | inc 001f.2959.e17f'
DR-3750-01#show mac address-table | inc 001f.2959.e17f
724 001f.2959.e17f DYNAMIC Gi1/1/1
We see the mac address! learnt dynamically from the uplink Gi1/1/1 to DC2-ASR1002-01.
And i've tested ping's from hosts in both sides and it works!
I have the same setup working with:
ASR1002 and ASR1001 with different versions of code! But to name a few, just because its quicker for me to do a show ver - here's what Im running.
ASR1002:
Cisco IOS Software, IOS-XE Software (PPC_LINUX_IOSD-ADVENTERPRISEK9-M), Version 15.2(2)S, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 26-Mar-12 15:23 by mcpre
IOS XE Version: 03.06.00.S
Cisco IOS-XE software, Copyright (c) 2005-2012 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
DR-ASR1002-01 uptime is 3 weeks, 15 hours, 45 minutes
Uptime for this control processor is 3 weeks, 15 hours, 47 minutes
System returned to ROM by reload at 17:39:43 UTC Wed Apr 3 2013
System restarted at 17:43:21 UTC Wed Apr 3 2013
System image file is "bootflash:asr1000rp1-adventerprisek9.03.06.00.S.152-2.S.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
cisco ASR1002 (2RU) processor with 1689232K/6147K bytes of memory.
Processor board ID FOX1603G9GE
4 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7757823K bytes of eUSB flash at bootflash:.
ASR1001
Cisco IOS Software, IOS-XE Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.2(2)S, RELEASE SOFTWARE (fc1)
Compiled Mon 26-Mar-12 16:23 by mcpre
software.
ROM: IOS-XE ROMMON
IH-ASR1001-01 uptime is 9 weeks, 4 days, 15 hours, 7 minutes
Uptime for this control processor is 9 weeks, 4 days, 15 hours, 8 minutes
System returned to ROM by reload at 18:19:04 UTC Sat Feb 16 2013
System restarted at 18:21:51 GMT Sat Feb 16 2013
System image file is "bootflash:asr1001-universalk9.03.06.00.S.152-2.S.bin"
License Level: advipservices
License Type: Permanent
Next reload license Level: advipservices
cisco ASR1001 (1RU) processor with 1163576K/6147K bytes of memory.
Processor board ID SSI16050CNJ
8 Gigabit Ethernet interfaces
7741439K bytes of eUSB flash at bootflash:.
I hope this helps others! I had a great experience when setting this up.
Also please make reference to official documentation too: http://www.cisco.com/en/US/docs/ios-xml/ios/wan_otv/configuration/xe-3s/asr1000/wan-otv-confg.html
Bilal
Good Document, I was just wondering if you have done even HSRP + OTV as well?
I am trying to bring up a setup for OTV now, but with what you have put, I will try to bring it up with loopback and see how it goes. If it doesn't come up, I will post my observations as part of this thread itself.
Thanks for your help.
Thank you Aries,
If you need some input from me, feel free to ask. I will attach the entire config from one of the ASR's which may be able to help.
I have tested it, and used it, but am not using this at the moment because we will be undergoing a DC migration.
Please see here for info. https://supportforums.cisco.com/thread/2210662
track 1 interface GigabitEthernet0/0/3 line-protocol
interface Loopback1
ip address 192.168.230.244 255.255.255.255
ip mtu 1600
ip pim sparse-mode
interface Loopback2
ip address 192.168.230.234 255.255.255.255
ip mtu 1600
ip pim sparse-mode
ip mtu 1600
ip pim passive
ip igmp version 3
interface Overlay1
no ip address
service instance 4 ethernet
encapsulation dot1q 4
bridge-domain 4
service instance 5 ethernet
encapsulation dot1q 5
bridge-domain 5
service instance 16 ethernet
encapsulation dot1q 16
bridge-domain 16
service instance 19 ethernet
encapsulation dot1q 19
bridge-domain 19
service instance 20 ethernet
encapsulation dot1q 20
bridge-domain 20
service instance 24 ethernet
encapsulation dot1q 24
bridge-domain 24
service instance 524 ethernet
encapsulation dot1q 524
bridge-domain 524
bridge-domain 724
service instance 725 ethernet
encapsulation dot1q 725
bridge-domain 725
interface GigabitEthernet0/0/0
description ## ASR Routing to ASR1002-02 ##
mtu 1700
ip address 192.168.230.1 255.255.255.252
ip pim sparse-mode
ip igmp version 3
negotiation auto
cdp enable
description ## Core Routing 6509-1 VLAN 592 IH ##
ip address 192.168.240.5 255.255.255.248
ip pim sparse-mode
ip ospf authentication
ip ospf dead-interval minimal hello-multiplier 5
ip ospf cost 2
negotiation auto
cdp enable
description ## OTV INSIDE to 6509-1 Gi9/13 ##
no ip address
negotiation auto
cdp enable
bridge-domain 4
bridge-domain 5
bridge-domain 8
bridge-domain 16
bridge-domain 19
bridge-domain 20
bridge-domain 24
bridge-domain 524
bridge-domain 724
bridge-domain 725
description ## OTV OUTSIDE to IASR1001-01 ##
mtu 1700
ip address 192.168.230.5 255.255.255.252
ip pim sparse-mode
ip ospf bfd
negotiation auto
bfd interval 50 min_rx 50 multiplier 5
cdp enable
interface GigabitEthernet0/1/0
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/1/1
ip address 192.168.250.5 255.255.255.248
ip pim sparse-mode
ip ospf cost 3
negotiation auto
cdp enable
interface GigabitEthernet0/1/2
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/1/3
description ## OTV OUTSIDE to DR-ASR1002-01 ##
mtu 1700
ip address 192.168.230.21 255.255.255.252
ip pim sparse-mode
ip ospf bfd
negotiation auto
cdp enable
interface GigabitEthernet0/1/4
description ## OTV OUTSIDE to ET-ASR1001-01 #
mtu 1700
ip address 192.168.230.33 255.255.255.252
ip pim sparse-mode
ip ospf bfd
negotiation auto
cdp enable
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
router ospf 1
router-id 192.168.230.244
area 0 authentication message-digest
network 192.168.230.0 0.0.0.255 area 0
network 192.168.240.0 0.0.0.255 area 0
network 192.168.250.0 0.0.0.255 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip pim rp-address 192.168.230.234
ip pim ssm default
ip msdp peer 192.168.230.243 connect-source Loopback1
ip msdp cache-sa-state
ip msdp originator-id Loopback1
ntp server 172.25.4.2 prefer
ntp server 172.25.4.3
event manager applet Int-Down
event track 1 state down
action 1.0 cli command "enable"
action 1.1 cli command "conf t"
action 1.2 cli command "interface overlay 1"
action 1.3 cli command "shutdown"
event manager applet Int-Up
event track 1 state up
action 1.3 cli command "no shutdown"
end
OTV on asr1000 doesn't support Loopback interfaces as join interface. Please fix this right away, as it confused some SEs.
I beg your pardon, excuse me, I have this working with loopback interfaces. YOU CANNOT TELL ME TO FIX SOMETHING THAT I HAVE WORKING! And do not try to tell me that it is not supported, because I'll prove you wrong.
If you find this is such a problem, email me please at bilal.ajaz.nawaz@gmail.com and we'll take this conversation offline.
Just thought I will prove you and others wrong (in the politest possible way with a video showing loopbacks used) since you had the audacity to tell me to "fix this right away"
Hi Bilal,
as part of XE-3.9, ASR1k is not supporting Loopback interface usage as part of the join-interface. I do not know the reason behind this. Can you kindly check this, since, I believe this was the reason for the above comment.
Hello Aries, As soon as the video comes up, you can see yourself. Does it take a while for video's to come up? Because at the moment its just going round in a circle.
Hi Bilal,
Cisco doesn't officially support loopback address as join interface on asr1000. This is a roadmap feature on asr1000. We only support features after proper internal testing. Even though the loopback cli may be available, but under full testing scenarios, you may run into issues. Thus, this configuration is not officially supported and it is not recommended for real customer deployments.
I appreciate you writing a blog about OTV. However I would like to reflect accurate information without misleading our customers. Please fix it ASAP.
I never ever said that Cisco officially supported loopback address as join interface.
Loopback in CLI is available and WORKS.
I never ever stated that using loopbacks for join interfaces is recommended either. If you take another read of the beginning of the post - the very very first sentance....
I have run OTV like this for over a year! and have never come across any issues whatsoever! In fact, its one of Cisco's close partners who came up with the configuration idea and testing too.
It doesn't matter if Cisco support it or not. It works. I'd also like to add, I've vmotioned VM's across DC's, run multicast across it, IPTV, IP Telephony. Not one single problem.
I'm not doing Cisco Sales here, I'm not a sales person.
Here's proof, OTV between sites....
Hi Bilal,
Just happened to check on the XE-3.9 release and this is what is observed:
Router(config-if)#otv join-interface loopback 10
% Configuration failed, virtual interface is not supported.
Router(config-if)#
So, if you were to upgrade your router's to the latest XE-3.9 or the upcoming XE-3.10 OTV would go down since the 'otv join-interface' command would be rejected.
Hi Aries, you are probably right, I will check this today if I get a chance. There are no plans to upgrade our fleet of ASRs since we are moving towards Nexus7Ks in our new DC. Everything is working perfectly and smoothly so no need to change short term.
I think that it should be accepted of the fact that OTV works with loopback interfaces as join interfaces. I have proven this. On the version of code I have and the ASR platforms. Even though Cisco say it isn't supported.
I believe I have nothing to fix. I have also stated on here which version of XE I am on.
It's just the new code you mentioned, that it may have been stopped from the CLI, however it is fully capable of running OTV off of loopback interfaces as you have seen for yourself.
I really don't mean this in a bad way at all, I just don't approve of someone telling me to fix something that I have working.
