Jason Pfeifer
Posted By:
cgrodde
Posted Date:
Jan 13, 2010
Category:
Network Management
Version:
1.0
License:
Cisco-Style BSD
Summary:
This monitoring script is reporting packet loss and rtt for e.g. wan links into rotating files
Script Modified Date:
Jan 14, 2010
Cisco IOS Version tested:
12.4(25b), 12.2(32)SRC2
Cisco Products Tested:
7200VXR, 7600
Environment Variables used:
pingmon_dstip, pingmon_interval, pingmon_repeat, pingmon_timeout, pingmon_data_dir, pingmon_loghist
Rating Count:
Average Rating:
File Size:
3.4 KB
Script Info URL:
pingmon offers an easy way to check if, eg. provider links works  fine. It is very useful if you don't have an external monitoring  software or you didn't trust it. pingmon is using standard cli ping. So  it is reporting packet loss, min, average and max rtt. It is running at  configurable intervals and sends as many pings as configured with the  repeat counter. Results are written to daily rotated files. To ensure  that flash isn't running out of memory the parameter "loghist" will keep  an eye on it. With log level "debugging" pingmon will forward messages  to the corresponding lines.
