michaelchung
I have a problem about Private VLAN. I sreach it in google in three days, but one people use this as difficult as my case. Hope someone can help.
My core switch in Cisco 4503, and I have two access switch Cisco 2960. I have a router with support many 802.1q subinterface.
I connect all device to Core switch as following
Core GigabitEthernet1/1<-->Router GigabitEthernet1/1
Core GigabitEthernet1/2<-->Access2 GigabitEthernet1/1
Core GigabitEthernet1/3 <--> Access2 GigabitEthernet1/1
I have a lot of VLAN in the switch.* I only want to isolate VLAN 100 traffic and allow it to the router only. I want to keep all other VLANs as normal.
Core
Vlan100
name Wireless
   private-vlan primary
  private-vlan association 101
Vlan101
  private-vlan isolated
interface GigabitEthernet1/1
description Connect to router with trunk link
switchport trunk allowed vlan 1,99,100,401-440,501-540
switchport private-vlan trunk allowed vlan 200,201
switchport private-vlan mapping 200 201
switchport mode private-vlan trunk promiscuous
spanning-tree portfast trunk
interface GigabitEthernet1/2
switchport trunk allowed vlan 1,100,401-440
switchport private-vlan trunk native vlan 1
switchport private-vlan trunk allowed vlan 100,101
switchport private-vlan association trunk 100 101
switchport nonegotiate
end
interface GigabitEthernet1/3
switchport trunk allowed vlan 1,100,501-540
end
Access1
interface GigabitEthernet0/1
description Connect to 4503
switchport mode trunk
Access2
My my whole network stop after I input above command.
Would anyone tell me what is the problem?
I want following question
1) Would "switchport trunk allowed" and "switchport private-vlan trunk allowed vlan" atcive at the same time?
2) In my access switch, this is not support PVLAN. Do you mean I need to change VLAN100 to VLAN101?
3) In my route should I keep subinterface in VLAN100 or need to more to VLAN101?
Thank you very much!
