shrihangupta
Community Member
hi everyboby hope all of u r doing well.
I have point to get clarify on route-map.after going thorgh lot of stuff i found that:
1> if in ACL is permitting a route then with route-map permit clause it will also permit.   ---- correct or incorrect ?
2> if in ACL is permitting a route then with route-map deny clause it will deny.---- correct or incorrect ?
3> if in ACL is denying a route then with route-map permit clause it will also deny. ---- correct or incorrect ?
4> if in ACL is denying a route then with route-map deny clause it will also deny.---- correct or incorrect ?
Pls help.
Shrihan
