anaiyar
Sample configuration for Voice and Data deployment on a Switch
Case 1: Phone and PC's on different/dedicated switch ports on the switch
Creating VLAN's
Voice VLAN
Switch#conf t
Switch(config)#vlan <VLAN ID>
Switch(config-vlan)#name Voice - description of the VLAN
Similarly for the Data VLAN
Creating VLAN interfaces (SVI's) and assigning IP address to them:
Switch#conf t
Switch(config)#interface vlan <VLAN ID>
Switch(config-if)#ip address <X.X.X.X> <X.X.X.X> - IP address Subnet Mask
(The ip address should be one of the useable IP addresses of the phone or data subnet)
Interface configuration - Data/Voice
Switch#conf t
Switch(config)#interface GigabitEthernet <interface ID>
Switch(config-if)#switchport mode access
Switch(config-if)#switchport access vlan <VLAN ID> - data VLAN in case of PC
or
Switch(config-if)#switchport voice vlan <VLAN ID> - Voice VLAN in case of phone
If QOS is to be applied
Switch(config)#mls qos  -  Enabline QOS globally on the switch
Switch(config-if)#auto qos voip trust
Case 2: PC's connected via switchport behind the IP phone.
Creating VLAN's
Voice VLAN
Switch#conf t
Switch#conf t
Switch#conf t
Switch(config-if)#switchport trunk encapsulation dot1q
Switch(config-if)#switchport mode trunk
Switch(config-if)#switchport trunk native vlan <VLAN ID> - Data VLAN
Switch(config-if)#switchport access vlan <VLAN ID> - Voice VLAN
OR
Switch#conf t
Switch(config-if)#switchport voice vlan <Voice VLAN ID>
* With newer IOS it is not required that a switchport connecting a phone piggybacking a PC to be configured as a trunk specifically. Please see the secondary configuration above.
Or
Switch(config-if)#auto qos voip trust cisco-phone (specifically for Cisco IP phones)
Note: The above mentioned commands are version specific, however are same or similar in most of the cases.
APPIREDDY
excellent. thanks for your open contribution. please post some more real time senarios, i mean seriously real time, where you see in companies.that would help someone, like us.
cheers
red
ajay pandey
Could someone confirm if I need the PC with 802.1 authentication which is connected via Avaya phone[without 802.1x authentication].
How should be that possible ?
shinojosa_cisco
Thank you!
alfista16
Hello. Some clarifications, if I may:
Switch#conf t
What is the point of defining an access vlan above? The switchport is in trunk mode.
Also:
Switch#conf t
What is the point on defining dot1q encapsulation above, since the switchport mode is access?
I believe switchport trunk encapsulation dot1q is not applying to Newer switches
