SunilKhanna
    Introduction:
    Time to live (TTL) Security Feature protects Exterior Border Gateway Protocols (EBGP) peering sessions from attacks by forged IP packets. The feature compares the TTL field of the incoming packet against the hop count configured for the EBGP neighbor. The BGP will establish and maintain the session only if the TTL value in the IP packet is equal to or greater than the TTL value configured for the peer.
    This feature is configured using neighbor <ip-address> ttl-security hops <count> BGP configuration command. The TTL value is calculated by the router from the configured hop count i.e. TTL = 255 - (hop count).
    This feature has few limitations
    1. On enabling neighbor ttl-security feature, neighbor ebgp-multihop is not required.
    2. The feature is only for EBGP and not IBGP.
    Prerequisites
    • Understanding of Interior Routing Protocols (EIGRP)
    • Understanding of Exterior Routing Protocol (BGP)
    Background
    In this document, four routers (R1, R2, R3 & R4) are connected via fast Ethernet interfaces and all are configured with EIGRP routing protocol as IGP. R1 and R4 are advertising their loopback 0 interface prefixes (1.1.1.1/32 and 4.4.4.4/32).
    R1 and R4 are in different Autonomous Systems 100 and 200 and forms the EBGP peering. R4 is originating BGP packets with a TTL of 255, and R1 expects the packets it receives from R4 to have at least 252 (as in BGP configuration of R1 has neighbor 4.4.4.4 ttl-security hops 3, so a TTL value 255-3=252).
    Any BGP packet originating behind R4, can’t reach R1 with a TTL of 252 and hence R1 will always reject that BGP packet.
    Topology Diagram
    Configuration
    R1R2R3R4
    hostname R1
    ip cef
    no ip domain lookup
    interface Loopback0
      ip address 1.1.1.1 255.255.255.255
    interface FastEthernet0/0
      ip address 10.12.12.1 255.255.255.252
      duplex auto
      speed auto
      router eigrp 10
      network 1.1.1.1 0.0.0.0
      network 10.12.12.1 0.0.0.0
      no auto-summary
      eigrp router-id 1.1.1.1
    router bgp 100
      no synchronization
      bgp router-id 1.1.1.1
      bgp log-neighbor-changes
      neighbor 4.4.4.4 remote-as 200
      neighbor 4.4.4.4 update-source Loopback0
      no auto-summary
    end
    hostname R2
    ip cef
    no ip domain lookup
      ip address 10.12.12.2 255.255.255.252
      duplex auto
      speed auto
    interface FastEthernet0/1
      ip address 10.23.23.1 255.255.255.252
      duplex auto
      speed auto
    router eigrp 10
      network 10.12.12.2 0.0.0.0
      network 10.23.23.1 0.0.0.0
      no auto-summary
    end
    hostname R3
    ip cef
    no ip domain lookup
      ip address 10.23.23.2 255.255.255.252
      duplex auto
      speed auto
      ip address 10.34.34.1 255.255.255.252
      duplex auto
      speed auto
    router eigrp 10
      network 10.23.23.2 0.0.0.0
      network 10.34.34.1 0.0.0.0
      no auto-summary
      eigrp router-id 3.3.3.3
    end
    hostname R4
    ip cef
    interface Loopback0
      ip address 4.4.4.4 255.255.255.255
      ip address 10.34.34.2 255.255.255.252
      duplex auto
      speed auto
    router eigrp 10
      network 4.4.4.4 0.0.0.0
      network 10.34.34.2 0.0.0.0
      no auto-summary
      eigrp router-id 4.4.4.4
    router bgp 200
      no synchronization
      bgp router-id 4.4.4.4
      neighbor 1.1.1.1 remote-as 100
      neighbor 1.1.1.1 ttl-security hops 3
      neighbor 1.1.1.1 update-source Loopback0
      no auto-summary
    end
    Verification
    R1#sh ip bgp sum
    BGP router identifier 1.1.1.1, local AS number 100
    BGP table version is 1, main routing table version 1
    Neighbor        V    AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
    4.4.4.4         4   200      23      22        1    0    0 00:10:14        0
    R1#sh ip bgp neighbors 4.4.4.4
    BGP neighbor is 4.4.4.4,  remote AS 200, external link
      BGP version 4, remote router ID 4.4.4.4
      BGP state = Established, up for 00:09:57
      Last read 00:00:00, last write 00:00:57, hold time is 180, keepalive interval is 60 seconds
      Neighbor capabilities:
        Route refresh: advertised and received(old & new)
        Address family IPv4 Unicast: advertised and received
      Message statistics:
        InQ depth is 0
        OutQ depth is 0
                             Sent       Rcvd
        Opens:                  3          3
        Notifications:          0          0
        Updates:                0          0
        Keepalives:            18         20
        Route Refresh:          0          0
        Total:                 21         23
      Default minimum time between advertisement runs is 30 seconds
      For address family: IPv4 Unicast
      BGP table version 1, neighbor version 1/0
    Output queue size : 0
      Index 1, Offset 0, Mask 0x2
      1 update-group member
                                     Sent       Rcvd
      Prefix activity:               ----       ----
        Prefixes Current:               0          0
        Prefixes Total:                 0          0
        Implicit Withdraw:              0          0
        Explicit Withdraw:              0          0
        Used as bestpath:             n/a          0
        Used as multipath:            n/a          0
                                       Outbound    Inbound
      Local Policy Denied Prefixes:    --------    -------
        Total:                                0          0
      Number of NLRIs in the update sent: max 0, min 0
      Connections established 3; dropped 2
      Last reset 00:10:00, due to User reset
      External BGP neighbor may be up to 3 hops away.
    Connection state is ESTAB, I/O status: 1, unread input bytes: 0
    Connection is ECN Disabled, Mininum incoming TTL 252, Outgoing TTL 255
    Local host: 1.1.1.1, Local port: 39378
    Foreign host: 4.4.4.4, Foreign port: 179
    Enqueued packets for retransmit: 0, input: 0  mis-ordered: 0 (0 bytes)
    Event Timers (current time is 0x271CD8):
    Timer          Starts    Wakeups            Next
    Retrans            13          0             0x0
    TimeWait            0          0             0x0
    AckHold            12          9             0x0
    SendWnd             0          0             0x0
    KeepAlive           0          0             0x0
    GiveUp              0          0             0x0
    PmtuAger            0          0             0x0
    DeadWait            0          0             0x0
    iss: 4147902773  snduna: 4147903047  sndnxt: 4147903047     sndwnd:  16111
    irs: 1221993724  rcvnxt: 1221994017  rcvwnd:      16092  delrcvwnd:    292
    SRTT: 528 ms, RTTO: 1584 ms, RTV: 1056 ms, KRTT: 0 ms
    minRTT: 348 ms, maxRTT: 892 ms, ACK hold: 200 ms
    Flags: active open, nagle
    IP Precedence value : 6
    Datagrams (max data segment is 536 bytes):
    Rcvd: 22 (out of order: 0), with data: 12, total data bytes: 292
    Sent: 24 (retransmit: 0, fastretransmit: 0, partialack: 0, Second Congestion: 0), with data: 12, total data bytes: 273
    NOTE: Now, if the ttl-security hops is changed to 2, R1 and R4 will not form an EBGP session.
    As seen, on changing the number of hops, the peering between R1 and R4 is lost.
    References
    BGP Support for TTL Security Check
    BGP Command Reference
    Cisco Support Page: Border Gateway Protocol
