Hello folks, I am looking to purchase the following switch as Layer 3 C9300X-24Y-A and following switch as Layer 2 C9200L-48P-4X-E. The current old switches 3850 & 3650 that are being replaced have the following SFP for the most part "SFP-10...
view more
Somehow I am not understanding the scant documentation on setting default routes for multiple circuits in VPN 0. It works for me with more than one circuit if they all are static IPs with static next hops. It works for a single circuit with DHCP. However,...
view more
If I have two 10Gig SFP setup in a port channel (vPC) from both my Primary Nexus 5k and my Secondary Nexus 5K going back to my core switch which is a 6807 VSS, so a primary and secondary but it's logically one switch. So one port on the Nexus primary...
view more
We have a Nexus 5K setup as a vPC pair. I can log into the "primary" do a config update and copy run start saves the config. If I log into the Secondary and make a config change, doing a copy run start results in: Sec# copy run start...
view more
We are looking at purchasing the CBS350-24P-4G but due to supply chain issues, only the CBS350-24P-4X is available. We will be using a fiber trunk link between this switch and a SG350-10MP. The SG350 only supports 1G SFP. Can 1G SFP's be used in the CBS35...
view more
