I'm new to all this.After a factory reset, I can attach the router to the internet with a static ip and ping 8.8.8.8 Installed 16port service module sm-es2-16-p. My goals are to attach all in home network devices to the 16 port switch with...
view more
Just recently upgraded the ios to current version. During startup, getting error messages %SYS-6-READ_BOOTFILE_FAIL: tftp://255.255.255.255 It will try like 3 times, then boot the current version. From my understanding, its the f...
view more
I have a remote IR829 that is running ir800-universalk9-mz.SPA.159-3.M4 making an EZVPN connection to a virtual ASA running asa9-14-4-12-smp-k8.bin. It works fine right now, but I am unable to upgrade past 9.14 code because the EZVPN connection keeps usin...
view more
Dear community, I was looking to find the answer in regards the following question: "What is the result returned when performing a TraceRoute from one end of the tunnel to the over end of the tunnel". If the Tunnel is GRE, or other protocols.&n...
view more
hello!i am interested to know if there is any way to create an EEM script that will send via syslog the verison of my NEXUS. for example:event manager applet VERISON_CHECKevent cli match "copy running-config startup-config"-> and then i want it to...
view more
